Help Feel really dismayed only had my thomson 44" rear projector for 2 year and colour wheel motor has gone , cant get part from manufactures cause they have gone bust , tried online parts shops , they cant get one . Someone sent me a message saying they would sell me there old tv for parts but he has only signed in as a guest so i cant seem to get back to him , Help!! any suggestions thanks !
    President:
  • 4,402 Answers
Try mcm electronics there were a rca dealer
Posted on Feb 01, 2008
New Colour Wheel Mixing up Colors on Dell Projector
Could be just 180degrees out of phase on the motor spindle and sensor or damage caused by broken material from the old wheel.
Apr 21, 2017 | Dell M209X Ultra Mobile Projector ...
I'm pretty sure my color wheel is broken, and would be fine W/ replacing myself, but can't find where I could buy one. I have learned that the collor wheel is supposed to have4 segments, and have 2x...
Simple answer No! Colour wheels do run at high speed (I think around 20,000rpm and you can get 4 and 6 segment colour wheels i.e for each colour.to get better colour definition for the higher end ones.
Remember the colour wheel is a precision device as It has to rotate in sync with the DMD chip as each different frame of colour information is sent to the dmd chip.
some important considersations for choosing another colour wheel- off the top of my head:
motor voltage and current
number of poles on stepper motor
size of motor- will it fit
diameter of colour wheel
purity of the colours etched onto the glass
mounting of the assembly
I'd be looking for an original, see if your authorised repaired would be happy to sell you a genuine one on the basis of no warranty no return.
but do give it a go if the repair cost and a genuine one is out of the ball park or similar cost to new
Good Luck!
Jan 16, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Thomson 44dlw617 noisy
That is called the Color Wheel !
May 15, 2009 | Thomson 44DLP542 Replacement Rear...
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Color problem
The part to clean is the sensor that wraps around the colour wheel or some thing on it's axle.
This sensor identifies when the colour wheel has made a revolution and syncs the video output to the right segment in the colour wheel so only the red image is displayed when the colourwheel is filtering red, etc...
If the sensor gets dirty it will not be able to tell exactly where the colourwheel is, and in my case started to report a segment off.
Consider this before you take your machine apart.. I live in New York City, and this area is rather dusty.. I've had my projector for 2 years running pretty constantly, so it was pretty dusty. I mention this because there are other possible causes to this problem. It could be an electronic issue.
There were three things that convinced me it was a colour wheel issue : 1) The problem appeared slowly over the period of about 2 weeks.. First it started flickering, and then all of a sudden it would switch back and forth.. 2) The color white was fine. In fact, the image was fine, just some colors were switched. I could even fix the image by adjusting the hue in my video.. 3) My machine was full of dust..
I don't know about the HP projectors, but this is the best I can do to describe how to locate the colour wheel...
If you take the bulb out of your projector, you'll probably see part of it.. The first thing wherever the bulb shines into is probably the colorwheel (or a protective cover). In my machine there is no way to access it from the bulb housing, so I had to take the entire case apart.
From there you can clearly see how the bulb shines through the colourwheel, and then then light enters a closed chamber (sealed, I assume, from dust).
If you are not able to locate the colorwheel after this, maybe take some pictures with the case apart and send them to me.. I'll look for a manual online in the meantime..
Also, I'd be happy to talk to you over skype to get more detail.
Nate
Jul 11, 2008 | Optoma H30 Multimedia Projector
Premature colour wheel replacement - design problem?
mcm electronics has it in stock Part # BP96-00674A $80.00
Jun 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Rear Projection
TRY contacting Parts suppliers like, VANCE BALDWIN ,TRITRONICS, MCM ELECTRONICS AND HERMAN/ PANSON For a few Charlie
Feb 12, 2008 | Thomson 28VK25US TV
Thomson tv
http://online.projectordoctor.com/Projector-TV-Lamps
http://beamerlampen.biz/projector-bulbs/projector-lamp-Thomson-44DLW617-Nr-5400.html
Dec 07, 2007 | Televison & Video
Processor is broke on our Thomson scenium 44" rear projector is it worth fixing or would it be to expensive
What do you mean by the processor is broken? Need more information on this set. What is the problem with the TV set? What model is it? Who said the processor(whatever that is) is broken?
Nov 26, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
