Remove Agitator Whirlpool style Top Loader
I've removed the cap from the top of the agitator (no comfort dispenser) and can access the bolt, but when i try and loosen it, it just spins anticlockwise with a slight grinding noise. Basically i can't get a purchase on the bolt to remove it, as it seems to be spinning independent of the upper and lower agitator parts. However, when the machine is in wash mode, i can observe the agitator bolt performing the slow clockwise (agitation) motion but it isn't moving the upper agitator and so the clothes are just sitting in standing water.
Any idea how i can get this sucker off? I'm pretty certain i have to replace the clutch dog ears and maybe the cam but i don't know how to get the agitator off without resorting to turning the washer upside down and getting at it from the bottom of the drum...any ideas?
Cheers,
col
  • 105 Answers
I think that the agatator may have a screw in the side of it nearer the bottom stem if so slacken off and pull ajatator off main shaft
if no screw just pull agatator off
sometimes takes a bit to get off
do not turn machine upside down
Posted on Feb 02, 2008
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool top-loader LSQ9200LQ0 The top half of the agitator is not turning. I am assuming it is a stripped part. What would be the best way to take this apart??
    You have what bad "agitator dogs". Yes this is a stripped out part. To get to the dogs, you will need to take the fabric softener dispenser off the top of the agitator (if your unit does not have a dispenser, then just take the cover of the agitator). Under that you will see a semi transparent cap that fits inside the shaft of the agitator, pull that straight up and out of the agitator. Now you can see the bolt that hold the agitator to the transmission shaft, this is a 1/2" or 9/16" bolt. You will need a socket with a long extension to reach this. Take a digital picture, or sketch the position of the dogs inside the agitator, this will help with the reassembly process. Once the bolt is out, the agitator will lift off. Turn the agitator upside down and depress the tabs up inside the shaft of the agitator, this will release the top of the agitator from the bottom, be careful, there are small parts that will fall out. Try to separate it in one piece, as this will make it easier to reassemble. Once separated, remove the old dogs and replace with the new, reassemble in reverse. When tightening the bolt, only tighten snug, the black rubber gasket should not bulge out when tightened. Also make sure the "o" ring on the semi transparent cover is in place and not broken. If you have questions, write me back. Hope this helps!
    Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
    How do i remove the agitator on my whirlpool ultimate care II top loader washer
    first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
    Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    How do you remove the agitator on amana washer model lwa30aw
    Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
    Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
    Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
    Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
    Aug 06, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    One part of agitator moves the other part doesnt.
    Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
    Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
    If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
    Agitator Removal Instructions:
    Remove Dispenser or Cap:
    Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
    Remove Internal Debris Cap:
    Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
    Remove Agitator Stud:
    When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
    Remove the Upper Agitator (Mover):
    With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
    Remove the Cam and Clutch Dogs:
    When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
    -- Stop Here if Replacing Cam Kit --
    Remove O-ring:
    The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
    Pull the Lower Agitator:
    All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
    Agitator Installation Instructions:
    Set Lower Agitator:
    Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
    -- Start Here if Replacing Cam Kit --
    Assemble Cam and Dogs:
    Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
    Install Cam and Dogs into Upper Agitator:
    Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
    Install the Upper Agitator (Mover) on the Lower Agitator:
    The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
    Install the Agitator Stud:
    Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
    Install Internal Debris Cap:
    Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
    Install the Dispenser or Cap:
    The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
    Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Removing Agitator from Kenmore Model 110 Top Loader
    How to replace Whirlpool/Kenmore washer
    dual action agitator ratchet ‘dogs’, kit # 285770
    Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
    1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
    2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
    3) Remove the bolt in the center of the agitator
    (Earlier models used a 7/16" hex-head steel bolt)
    (Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
    4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
    (Recent models allow just the top portion’s removal to access these ‘dogs’)
    5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
    6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
    7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
    8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
    9) Reach around and pat yourself on the back! You just saved at least $75.00!
    Dec 31, 2008 | Kenmore Washing Machines
    Noisy/loose agitator
    remove the top piece of the agitator. this is a dispenser. then remove a cap that is at the center of the agitator. there is a bolt there that is holding the whole agitator. remove the bolt and you can pull out the whole agitator. be careful in removing, the thing could just separate to pieces and you may have a problem assembling it again.
    tnx 4 using fixya,
    drcool
    Oct 14, 2008 | Whirlpool Washing Machines
    Whirlpool top load washer
    Bill,
    On most top load whirpool washers (not including the calypso or the cabrillo) there are 2 main styles for getting the agitator off.
    The first and easiet are for the older styles. This will be easy to identify as there is a green ring around the fabric softner dispenser holding it on. Raise the ring up and the dispenser will come off. Underneath you will see a plastic cap. Pry this off with a small flat hear screw driver. Underneath there, there will be a 7/16" bolt. Take it off with a rachet and lift the agitator from the bottom and out of the way.
    The second and slightly more complicated method is for the new style. This can be identified by the 4 evenly spaced slots just underneath the fabric softner dispenser. First gently rock the top of the fabric softner side to side. the white top should come off as well as a clear plastic cup underneath. You will be left with 4 white plastic shafts sticking up just above thse slots mentioned earlier. Taking care not to break these shafts, rotate the remaining top piece of the agitator counter clock wise. Once it rotates, pull/ pry it off. Underneath there will be a clear plastic cap with 2 tabs on it. Pull the cap off by these tabs. Remove the remaining 7/16 bolt underneath and lift the agitator off by the bottom.
    There are many variations of agitators, but one of these 2 methods (or even a mixture) should get you taken care of. One other thing to mention. Once you take either of the perviously mentioned styles off, you may find a white square hole under neath the dispensers. With this style, you use a 1/2" rachet to unscrew it counter clockwise and the 7/16 bolt is underneath.
    If this doesn't seem to match what you have, get me the model number (just underneath the lid to the center rear) and I can get you some step by step directions just for your model.
    Aug 01, 2008 | Washing Machines
    My whirlpool top loader won't agitate.
    Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
    Oct 12, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Agitator-How do you get it off?
    (Roper is actually made by Whirlpool) This is simpler than it sounds, just takes time and a few steps. Do you have a fabric softener dispenser that resides on top of the agitator? This dispenser simply snaps onto the top of the agitator. Some styles use a decorative cap. To remove the dispenser, simply grab it and firmly pull up. There is a cap that covers the bolt or nut that holds the agitator in place. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (the part that moves). Use a twisting or prying action to pop the cap off of the agitator. Sometimes there is a little slot where you can insert the screwdriver. Look for it first. There maybe an internal debris cap under this: Inside the agitator you will see a cap with a raised handle. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring. Removing the agitator: When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt or nut from the agitator stud. Don't use plyers, it'll just mess up the nut. With the bolt removed you should be able to remove the agitator by simply pulling up. Twist back and forth CW & CCW when lifting. Some are a 2 piece design, so pulling up will actually remove either the whole agitator assembly or only half of it. If whole assy comes up and you may need to seperate the two for your new parts. Place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator. As far as your parts go I'm not sure where they go without seeing it myself. There is a spline or ratch assembly which causes the agitator to move back and forth. They are usually made of plastic and get worn or break. This might be what you are replacing. It's not clear as to what parts they gave you. Good Luck
    Jul 17, 2007 | Roper RAS8445KQ Top Load Washer
    Washing Machines Logo
    489 people viewed this question
    Top Washing Machines Experts
