Question about Uniden TRU9480 Cordless Telephone
Caller id I need to know how to set phone to show caller id # when I am on a line and another caller is trying to call me. The phone shows caller id when you are not on phone and 1 person is calling, but I need it to show caller id # if I am on a call and someone else is calling me.
  • Anonymous Mar 14, 2014
    Caller ID does not keep all calls in history. Only keeps (3) per day in lieu of may 6 calls 1 day & then 4 from previous day. Only (3) from current day, (3) from previous day & (3) day before that
  • Anonymous Mar 27, 2014
    Incoming caller Id display
  • 65 Answers
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Posted on Feb 02, 2008
  • Anonymous Feb 03, 2008
    FROM MANUAL
    To active features, select the CALL WAITING submenu and the CALL WAIT DELUXE submenu to ON. See
    page 20.
    If you don’t choose a CWDX option within 30 seconds, the phone returns to the call.
    To return to the call, press the BACK soft key.
    When you receive a Call Waiting call, press the MENU soft key.
    Move the cursor to CALLWAITDELUXE, and then press the OK soft key.
    Move the cursor or use the number keypad [1-7] to select an option.
    Ask to Hold — A prerecorded message states that the user will be available
    shortly, and the call is place on hold.
    Tell Busy — A prerecorded message tells the caller you are busy, and the waiting
    call is disconnected.
    Forward — The caller is sent to your voice mail box, if available.
    Answer/Drop — Disconnects the first call, and connects to the new caller.
    Conference — Starts a conference call with your first and second callers.
    Drop First/Drop Last — During a conference call, allows you to choose to drop the first or last caller.
    Press the OK soft key. A confirmation screen will appear, and the phone returns to the call.
    1:Ask to Hold2:Tell Busy3:ForwardBACKDELETEOK1:Ask to Hold2:Tell Busy3:ForwardBACKDELETEOK
6ya staff
SOURCE:
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
http://www.retrevo.com/support/Sony-IT-M602-Telephones-manual/id/751bh629/t/2/
Mar 10, 2010 | Sony IT M602 Corded Phone
Need to know if caller id can be manipulated in an avaya system?
That is something you have to set up with the line provider. Partner can not send caller ID information
Feb 18, 2009 | Avaya IP Office 4690...
Caller Id not showing up
go on settings and on call settings and caller id
Jan 25, 2009 | AT&T 650530003417 Cordless Phone
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Caller id not working, called tele ph comp they said to change batt, have base unit with one in other room, base one and two not showing caller id, the batt are showing full.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Oct 29, 2008 | Lands Phones
Caller ID??
the phone is not equipped to handle caller ID
Oct 17, 2008 | GE RCA 4-Line Speakerphone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Uniden TRU9480 Cordless Telephone Logo
1,360 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
