Question about Samsung PLH403W 40" Rear Projection Television
Samsum PLH403W service menu
Do know how do I get to the service menu on my Samsung PLH403W iLCD TV?
  • Samsung Master
  • 8,617 Answers
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Posted on Feb 02, 2008
CODIGO DE TV SAMSUM
Here are the codes for the Samsung TV: 738, 680, 833, 516, 666, 679, or 664.
I have also provided the instructions on how to program your DISH remote to your TV.
AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
  1. Press the Pound (#) button - The mode button you are programming should flash three times
  2. Press the large, red POWER button - The device should turn off
If you have further questions, please let me know. Thanks.
Dec 25, 2011 | Sony RMVZ220 Remote Control
My screen seem to be really dark. I just got the TV from my older brother, hand me downs. What could i do to make the picture more clear?
Hi Friend,
Try to reduce the Display Colour and the Brightness of the picture and then check it
Regards,
Ayyasam
Apr 03, 2010 | Samsung PLH403W 40" Rear Projection...
Samsung PS50C96HD TV - Switches on for 3 seconds then switches it self off
CHECK UR POWER SETTING AND SLEEP TIMER......U MAY HAVE TO ADJUST OR RESET IT
IF THIS IS NOT THE PROBPLEM GO IN TOUCH WITH SAMSUM SERVICE,,,,,,,
Nov 20, 2009 | Samsung PS42P2S 42 in. Plasma Television
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Samsung hlr5667w green screen issue
test test test 16:47 do not answer
please do not answer test test test
Jul 05, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
No signal
LOOK N THE MAIN MENU ON THE SATELITE CONVERTER BOX LOCATE WHAT CHANNEL TV IS PROGRAMMED TOO TUNE TV TO THAT CHANNEL WILL EITHER WORK ON AIR OR CABLE
Dec 13, 2008 | Televison & Video
Samsung PLH403W Projection TV Lamp Problem
Maybe try removing the dust filter on the back and cleaning it. If I recall correctly the TV won't turn on unless the filter is clean and fully snapped back into position.
Aug 10, 2007 | Samsung PLH403W 40" Rear Projection...
Samsung plh403ws
You have something wrong in the eeprom, more than likely an option code, you will need someone with experience and trained on Samsungs to correct this, it was probably caused by either someone who shouldnt have been in the service menu or possibly by a close lightning strike, either way call a repairman.
May 08, 2007 | Samsung PLH403W 40" Rear Projection...
Samsung PLH403W 40" Rear Projection Television Logo
402 people viewed this question
Jerry Greenberg
Jerry Greenberg
