1st the LCD must have Time settings,and Teletext incorporated then press a remote control key to have time displayed, and config the LCD menu for clock always visible.
Based on the symptoms you described for your Hisense model 50h5c TV, it seems that there may be a hardware issue affecting the display. Without being able to diagnose the TV in person, it is challenging to pinpoint the exact parts that may need replacement. However, there are a few components that commonly contribute to display issues:
T-Con Board: The T-Con (Timing Control) board controls the timing and signals sent to the display panel. If there are issues with half of the screen or black screen with half lines, a malfunctioning T-Con board could be a potential culprit.
Display Panel: The display panel itself could be defective, causing the black screen or half-line issue. Unfortunately, replacing the display panel can be costly and often not cost-effective compared to purchasing a new TV.
Main Board: The main board handles various functions of the TV, including signal processing and overall control. In some cases, issues with the main board can cause display problems.
please follow this steps and fix it. God bless you
Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
The DXI4286-2 is an Analog phone, it does not allow for both handset to be used at the same time. You can transfer a call from one handset to another, but cannot talk on both at the same time.
The following is from the user's manual for your phone:
Unavailable message is displayed on the LCD screen of the handset. • Make sure the other handset is not already in use. Both handsets cannot be in talk mode at the same time. • Place the handset in the main base for at least 5 seconds to re-register to the main base. • Make sure the handset is not too far from the main base when trying to use.
You might want to try one of the DECT or a Digital 2.4 or 5.8 GHz phones, they allow you to use multiple handsets at the same time.
here i hope this helps you Display Settings Changing the Text Greeting The text greeting can be up to 15 characters and is displayed on your phone’s screen in standby mode. You may choose to keep the phone’s default greeting (“Sprint”), or you may enter your own custom greeting. To display or change your greeting: 1. Select > Settings > Display > Greeting > Custom. 2. Enter a custom greeting using your keypad and press . (See “Entering Text”on page 39.) (To erase the existing greeting one character at a time, press . To erase the entire greeting, press and hold .) Changing the BacklightTime Length The backlight setting lets you select how long the display screen and keypad remain backlit after any keypress is made. To change the Main LCD or Sub LCD backlight setting: 1. Select > Settings > Display > Backlight. 2. Select Main LCDor Sub LCD. 3. Select Always On, Dim Only, or a preset length of time. To change the Keypad backlight setting: 1. Select >Settings>Display>Backlight>Key. 2. Select Always Off or a preset length of time. Note: Long backlight settings affect the battery’s talk and standby times. Note: The Always On setting returns to the previous value the next time you turn on the phone. Your Phone’s
the phone number should be retrieved from the sim card or carrier login procedure.
I had a few blackberry's, including a 75xx series one, and when I popped in another card (I have a couple of prepaid subscriptions for testing), the number always came up automatically.
Should work... If not, try contacting RIM/Blackberry support, but I doubt they'll still give support for the 7xxx series models... sorry
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Possible with all cell phones.
Go to settings. set time and date, click on show time and date and click ok.Whoala! you have a time on main screen. If you have trouble go to nearest retailer they can help you for free.
