maybe there's a worn belt inside that keep on turning the motor and indicating an error through the four LEDs. it may need a repair, and in case of worn belt, replace the belt.
i have a problem about burning a vcd. ive got a nero 6 application in my dell optiplex Pc. i put a...
(More)
i have a problem about burning a vcd. ive got a nero 6 application in my dell optiplex Pc. i put a blank cd-r into the liteon dvd drive. after i imported the needed mpg video files in nero vcd maker, it takes a lot of time to burn, and when it reached 100%, the software then ask me to save the image file of the compilation, and the process ended. But when i tried to test the vcd, it prompted as if its blank. Is there a possibity that the mpeg files were not burned in the blank cd? Or maybe im just lacking of the right procedures to follow. please let me know. thanks
PX -W4824A I had the old uninstalled EZCD Creator 4 from XP SP3 and had to use the delete the Upper...
(More)
PX -W4824A I had the old uninstalled EZCD Creator 4 from XP SP3 and had to use the delete the Upper & Lower Filters in the registry fix to get Device Manager to remove the yellow triangle exclamation points from my CD drives problem. Once the drives were recognized both in Device Manager & Windows Explorer (this was happening to an old Creative DVD-ROM drive, too) neither would acknowledge a CD in the tray "Please insert a disk into drive #:" even with a formatted or recorded audio CD or an OEM data / software CD. After a firmware upgrade to the Plextor and an uninstall / reinstall in Device Manager for both they will both read a CD sometimes but most of the time they will NOT. Some times if the CD was in the drive on reboot they won't read it until the disc is ejected and the tray re closed. Plextor sometimes identifies in Windows Explorer as CD-RW Drive but mostly as CD Drive. Autoplay also executes intermittently. Help will be greatly appreciated.
I installed my old plexwiter on my newer computer and the drive slows my computer down and it will...
(More)
I installed my old plexwiter on my newer computer and the drive slows my computer down and it will not read any disks. Sometimes it will read music CD's and play them, but it will not reasd any other CD's, software CD's included. Sometimes it will not read any at all. I do have the driver. Sometimes it will freeze my computer, but if I open it and close it my computer ressumes. Also if I do this and just leave it open it will not close after a whils. Please Help.
