Question about Canon Pixma MP500 All-In-One InkJet Printer
How to remove printhead from canon i860
I would like to try and clean the print head on my canon i860 printer before I invest in either a new print head or new printer altogether. I can't figure out how to remove it. I don't see any screws readily visable. Any thoughts on how I can do this without breaking something?
Thanks
  • 1 more comment
  • orario Mar 21, 2008
    ink tanks jam
  • Anonymous Mar 26, 2014
    where can I purchase a new printhead
    clean print head
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Posted on Feb 29, 2008
  • 30 Answers
There is a small arm to the right (that's your right while looking at the front of the machine) of the printhead. It simply lifts up and then the head will be easily pulled out. There are no screws or anything.
Posted on Feb 07, 2008
Ink Player, thank you i used your advise to clean the print heads. It now works saving me time and money from buying new print heads.
Posted on Jul 11, 2008
I am getting 5 flashing yellow lights. As far asI can tell from the manual it appears I will need a new print head. Can it be cleaned or is it done?
Yes, that is a printhead fail. Printheads are almost as expensive as a new printer for the Pixma iP4000. You can find the printhead on eBay, runs $50-$80. Better to put that money towards a newer printer. You can also look for scrapped or damaged i860, iP4000, MP780, MP760, MP750 model printers and salvage the printhead from those.
Mar 18, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
3e black cartridge not printing. Canon i860
Did you try another cartridge?
What can happen sometimes is that the print head can get blocked.
You can clean that by removing the print head from the printer. Do not touch the foil on the head or the print nozzles.
Boil some water, pour 1/4 of an inch (6mm) of water into a saucer, place the print nozzles in the water for a minute or so.
Take the print head out of the water and touch it on a paper towel to get the water off.
Reassemble the printer and see what happens...
Feb 20, 2010 | Canon Office Equipment & Supplies
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
Canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Sep 15, 2008 | Canon i860 InkJet Photo Printer
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
Print head cleaning/cleaner
I've had some success, if one hasn't been printing with the ink dry for awhile , through soaking the entire printhead in a bowl of alcohol. Soaked it for 1-2 days wiping it from time to time. Took awhile, but it worked. Might have to do it again soon. Bottle of rubbing alcohol 80 cents. New print head $38. Rather waste the bottle of alcohol :P
I have not had great success at all with my brother's canon. He ran it clogged for almost a year and I tried the above and it didn't work. I'd say the transistors in the print head probably overheated and it's shot so he bought a new one. Too bad Canon doesn't make it easier to buy new printheads.
Nov 14, 2007 | Canon Office Equipment & Supplies
Canon Pixma MP500 All-In-One InkJet Printer Logo
8,516 people viewed this question
old marine
old marine
