Question about Sewing Machines
Machine not sewing
Even though I think I have threaded machine correctly it does not sew fabric together. Just cuts fabric off but does not sew it! Help needed pls! I think I've threaded by overlocker right (Riccar RL 913) but the stitching aint right, threads not weaving together, Needle is stitching on top but no back stitches while the lower & upper loops just trail along. What I am doing wrong?
  • 8 more comments
  • shelltea Apr 24, 2009
    I have the same problem and i think that i may have sone something to the timings any help would be grateful
    Shell
  • Anonymous Mar 12, 2014
    Machine is not sewing it looks like upper loop comes 1/8 inch above the needle tip I have the wright needle for the machine threading is correct what can be wrong is there any way I can fix
    My huskylock 905 is jamming, I sent it for repairs and it sewed great for about 10 minutes then just jammed again. The repairer has offered to refund my money but that doesn't solve my problem. He thinks it may have something to do with needing oil inside somewhere. Any suggestions about where I should oil it as the only dealer is some distance away and it can take 3-4 weeks to get the machine back due to his heavy workload
    my mauser industrial overlocker wont overlock on fabric. The threads all stay in a line and wont sew
  • Anonymous Mar 14, 2014
    bought a used Global 4 thread industrial overlock machine.. worked great when I bought it. Had to dismantle motor and machine from table to carry downstairs.. .reassembled and now handwheel turns in opposite direction and fabric feeds forward.
  • Anonymous Mar 23, 2014
    I cannot understand the instruction booklet for the above overlocker sewing machine. Cannot even thread it let alone start to sew!
  • Anonymous Mar 26, 2014
    I cannot thread the sewing machine
  • Anonymous Mar 27, 2014
    help, machine won't pick up threads, motor works great, checked the tention and it's fine, just won't sew the fabric together
  • Anonymous Mar 29, 2014
    The overlocker is looping but not stitching on stretch fabric.
    The overlocker is looping. However when I start stitching, does not catch on the fabric. only threads appear. When fabric is taken out, chain s are still there.
  • Sewing Machines Master
  • 1,388 Answers
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
  • Debra Barry
    Debra Barry Apr 26, 2014
    I have re-threaded my machine and that didn't help. I haven't gotten the surger to start sewing due to the error message that the upper knike needs tobe lowered (which it is). I am trying to do a cover stitch, I have it threaded properly and I lowered the knife. It is also in the "R" rolled hem position, as my guide instructs, but still, I close all the covers and it beeps that the upper knife needs to be lowered! Frustrating!
Why does bobbin make thread bunch up
Thread tension is incorrect. See the links
Incorrect thread tension - Brother Solutions Center
support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=hf_ns55eas...
Jul 30, 2014 - Turn the thread tension dial to select an appropriate thread tension. The appropriate thread tension differs according to the type of fabric and thread being used. ... If the upper threading and lower threading are incorrect, the thread tension cannot be adjusted correctly, even by turning the thread tension dial.
Sewing Lesson 10: How to Fix Tension on Your Sewing Machine - Oh ...
ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html Incorrectly threaded machine: Did you use all thread guides? Did you thread with the presser foot down,which would keep the thread from slipping fully between tension discs? Is thread unwinding freely from the spool, or catching on the spool's slash? Are you using a bobbin as a spool (which can interfere with the thread ...
Understanding Thread Tension on Your Sewing Machine - Threads
www.threadsmagazine.com/2008/11/02/understanding-thread-tension Nov 2, 2008 - When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbin thread, too tight, as shown in the bottom drawing at right.
Correct vs Incorrect Tension: Your Tension Troubleshooting Guide
www.sewingreviews.org/correct-vs-incorrect-tension-your-tension-troubleshooting-gu... I've seen many sewers make the mistake of using the same tension setting for all their sewing projects and then they wonder why the finish isn't perfect. The fact is, the wrong tension is a sewing disaster. It can ruin your sewing project and literally give you a tension headache. Knowing how to troubleshoot your tension ...
Sewing Machine Thread Tension - Updated - YouTube
? 8:51
https://www.youtube.com/watch?v=sf6oPMbLPzo Jul 12, 2016 - Uploaded by Professor Pincushion
Learn how to correct thread tension so that your stitches come out perfect no matter the type of fabric you're ...
Thread Tension - The Sewing Directory
https://www.thesewingdirectory.co.uk/thread-tension/ When sewing fabrics together problems can occur when the thread tension is not correct, the needle or bobbin is not inserted properly, or the machine is not threaded correctly. Threading instructions for sewing machines and overlockers are included in the machine's manual and should be consulted before you start sewing ...
Incorrect thread tension ' Brother CE1100PRW User Manual ' Page 89 ...
www.manualsdir.com > Brands > Brother manuals > Sewing machines > CE1100PRW Brother CE1100PRW User Manual • Incorrect thread tension • Brother Sewing machines.
images for Thread tension is incorrect.
More images for Thread tension is incorrect.Report images
How to Adjust the Tension on a Sewing Machine: 13 Steps
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Apr 08, 2018 | Sewing Machines
My serger singer 14u-544 cuts the fabric but doesn't sew. Whar can I do? Thanks
Probably due to incorrect threading or else one of the needles are bent. I had the same problem and it was the threading and the tension.frustrating as all get out.
Jun 23, 2017 | Singer Sewing Machines
Juki hl sewing machine thread not sewing
Is there power to the machine? Will the needle move? Did you switch the bobbin winder off? (Even if you think you have, try it again.) Is the machine clean and properly threaded? Can you use the handwheel to raise the bobbin thread? Did you hold the bottom and top threads together behind the presser foot when starting the seam? Is the needle new and right way around and fully up in the needle clamp? Can you sew on paper, but not fabric? Did you drop the presser foot?
Some more information would really help. (So would a complete model number!)
May 02, 2014 | Juki Sewing Machines
Threads not sewing
try a new needle
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case correctly
also could be a timing problem
Nov 27, 2013 | Janome Sewing Machines
Thread cuts at needle immediately when starting to sew.
check the needle plate for any small burrs
also on the bobbin & bobbin case
is the needle the correct one for the fabric being sewed?
Apr 17, 2012 | Brother LS-2125 Mechanical Sewing Machine
When i use sewing cloth in backside the thread will too loose then i use tension tight it correct in 8 number but manual book says 4 or 5 is correct wat can i do help me
Unthread your machine and set the tension to 4.5. rethread your machine up to the needle and then put the presser foot down. If the thread pulls hard, your machine is threaded right if it pulls easily, the thread is not thru the tension wheel correctly.
Rule of thumb:: loops on the top, problem on the bottom.
loops on the bottom, problem on the top.
May 15, 2009 | Singer 8280 Mechanical Sewing Machine
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Janome 1600P-DB Tension Works For So Long...
It sounds as though the thread is jumping out of the tension assembly. The next time this happens, do not raise the presser foot before you do the following.Cut the thread above the needle and pull on it.If it is working properly there will be tension on it.If it is not working properly, the thread will pull through very easily.If the thread is coming out of the tension , either it isn't threaded correctly or you may need to wrap the thread around the bobbin winder guide to keep it from coming out.If you wrap it around the bobbin winder guide reduce the tension to around 2 , 3 or even less.
Hope this helps.
sewman7
Jan 16, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Machine not sewing
 If you have the machine threaded correctly, and are absolutely sure. New needles installed and it still does not sew, you most definitely have a timing problem. You should take to a qualified service center to be properly timed.
Sep 05, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
637 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
