Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Dishwasher is about 7 years old and water has always remained in the in the base - not actually on the floor of the dishwasher but in the lower part where the spinning washer part it. I take a food baster and remove it to prevent odor from sitting water. Can you help? Thank you.
  • mimhoff Feb 02, 2008
    Thanks - I will try your suggestions.
  • Anonymous Apr 02, 2008
    My Bosch dishwasher is 11 years old and has run well until now. It won't drain and will not run at all. When the dial to run is turned, you can hear the timer running, but the typical start-up does not happen. I'm wondering if the drain pump has stopped working and that this sends a signal for the rest of the process to run. I tried to clear the slots in the drain area, but that has no effect. What do you think?
Have Bosch water stand in bottom drain. #SHU3302vc/U12
Posted on Apr 01, 2008
  • 130 Answers
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Posted on Feb 02, 2008
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
I have a dishwasher standing on the floor. I need that the water coming out of the dishwasher will come out to the sink because I have no dishwasher preparation. There is a height difference of 40-50 cm...
Hi Sharonl100,
Yes you will have no problem if you use the sink, I would however recommend that you lower the drain hose after each wash to the floor (emptying into a bucket or somesuch), and siphoning any remaining water from the machine.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 10, 2011 | Dishwashers
My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Feb 11, 2010 | Dishwashers
Water not pumped out of dishwasher
To cut a long story short, lower the drain pipe as close to the floor as you can. Some dish washers have a non return rubber which holds the water in the cabinet until asked to drain.Meaning water wont just flow out with pipe being low.(Im assuming the drain pump is operating correctly).Check if this alteration makes any difference.
Nov 13, 2009 | Dishwashers
Hi, hoover hed6612-80 when the door is opened the
The problem is most likely that the drain is blocked. Remove the lower front panel on the dishwasher. You will see the drain hose connected to a small pump close to the floor. disconnect the hose and remove the pump. There will be some water so be prepared with some paper towels, or rags. Remove the small pump so you can visually inspect it on the inside, remove any debris you find. If there is no debris there go under the kitchen sink and disconnect the other end of the dishwasher hose. you can then remove the entire hose to inspect it for a blockage. If no blockage in the hose, you must then check the path of the drain water through the garbage disposal [if you have one] and then the trap.
Oct 01, 2009 | Dishwashers
No water?
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 24, 2009 | Dishwashers
Water on floor after Kenmore dishwasher runs
you could fix this, however the price of repair will be 1/2 of the price of a new dishasher.  I would suggest you buy a new oneand not waste money on a six year old dishwasher.  find a good scratch and dent model.
Mar 15, 2009 | Kenmore Dishwashers
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
907 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
