Question about Sony PlayStation Portable (PSP) Console
It Turns Off!
Hi, when I turn on the PSP and go to the game, the beginning of the game starts with the credits and everything but the whole things just turns off afterwards. I can go into the main menu and everything but as soon as I try to start the game, it turns off. Every now and then I can get back into it but not whenever I want.
Am I doing something wrong?
  • icare Feb 01, 2008
    Well it does it when it is plugged in as well, and it turns back on right away. Its as if it cant actually load the game, but it can detect it...
    How do I update the firmware??
Try updating the firmware... and tell me the results..
Posted on Feb 01, 2008
    Scholar:
  • 152 Answers
When it turns off, does it takes time to turn on again? because it must mean that something must be overheating... how old is the device?
because the other thing could be the battery.. test with another battery
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
When I put in the Homefront game into my xbox 360, it begins to load it. It loads the credits perfectly, but after the "Kaos Studios" credit finishes loading the screen turns black and freezes....
i experience the same thing with my call of duty black ops what i did is go back to the store where i bought the game let them test it on there xbox and when they experience the same thing they just replace it with a new one and it then work properly...the problem is in the cd
Mar 17, 2011 | THQ Homefront for Xbox 360
My psp turns off without warning when i dont move the power switch. turns off in the middle off game and resets itself
If ur psP console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem, don't worry check out the following Repair Guide....
click here to download repair guide
Dec 21, 2010 | Sony PlayStation Portable (PSP) Console
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
Game loads then freezes and psp turns off by itself
you have turn off the psp then take out battery then look at laser then move it to the right and put the game in then go to auto start if on turn off then go to ad hoc mode change channel to 6 reboot it
May 10, 2009 | Sony PlayStation Portable (PSP) Console
My psp dosen't work well
have you modded the psp in anyway? are you trying to use homebrew apps? if you are trying to use a umd and you have modified anything other than stock then you need to clock your psp back to the factory level because the voltage is dropping too low from the umd reader activating and the strain the cpu is putting on the battery you could also try resetting everything to factory defaults afterall this is what the games are designed for
Mar 16, 2009 | Sony PlayStation Portable (PSP) Slim...
I put in a game and the psp system froze i cant turn of!!!
Try to remove the memory card. Reboot the PSP. Also make sure that you save the game files on the correct root folder in PSP.
If PSP will still not boot without the memory card. Bring PSP to Sony Service Center.
But if it boots up without memory card. Try to erase all data on memory card. Thre could be a virus or malware there causing the malfunction.
If it still fails, reset the whole thing and erase everything for a clean start.
Thank you.
Jan 03, 2009 | Sony ACY-BR81/OB
Psp
TAKE THE BATTARY OUT AND REINSERT IT
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
