Question about Apple Mac OS X 10.4 Tiger for Mac
Ftp i need help setting up ftp for macintosh using dynamic ip .i have it setup already .working within the LAN.But cant seem to make it work outside
  • 3 Answers
Try this link
http://www.ifelix.co.uk/tech/3008.html
Posted on Feb 01, 2008
Hi, I am setting up a website but i cant use my dynamic IP address because when i type my ip address in bowser its login into my ADSL 2+ Router . How could i divert it into my computer if my LAN IP Adress...
you need to let your router / modem router know what server will be exposed to the DMZ (example: assuming that 192.168.1.20 will be the webserver) that will redirect all the incoming traffic in port 80 the the 192.168.1.20 IP address and don't forget to open the ports in which the server will listen for connections. ( example: port 80 is http and port 443 is https )
if you have a dynamic IP you should consider using something like NO-IP.org or dyndns.org they will keep your dynamic IP up to date everytime it changes without you to have do the updates manually.
Dec 11, 2010 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
Cant create game server due to NAT settings
Make sure that you are using 1:1 NAT and not dynamic NAT, but more likely its a configuration issue. Some game servers like private WoW servers or Armagetron work better when the configuration file is setup with the computers IP and not "localhost" which is technically 127.0.0.1 and not Nat'd.
Jan 14, 2009 | Linksys Wireless-G WRT54G Router
Can not access my dwl-g700ap wireless to configure for some reason my laptop cant find it. it has been working fine for about a year now and was working fine but now doesnt seem to be working. how do i...
Connect directly to the AP with a cat5 cable,
you need to set a static IP in your laptop.
Start > control panel >netwrok connections> right click on your LAN icon > properties
In the main box, highlight "Internet Protocol/TCP/IP ", then click on properties.
Check the button "use the following IP address"
Put these settings in:
IP = 192.168.0.100
Subnet mask: 255.255.255.0
Gateway: 192.168.0.50
Click ok.
Then go to your browser and type in 192.168.0.50. This should get you into the setup page.
There you have to inputer the routers wirteless MAC address in the box labeled "repeater mode"
You may need to update the AP's firmware, here is how to do it:
http://www.ska2.obec.go.th/webboard/photo/137.pdf
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 07, 2008 | Computers & Internet
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Apple Mac OS X 10.4 Tiger for Mac Logo
88 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
