Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor bulbs blink on and off
I have a kogi monitor that the bulbs blink on and off I can see the picture from the computer for a split second as the bulb comes on but it will not stay lit.
  • Anonymous Aug 04, 2008
    mine started the same problem yesterday the green light comes on for a few seconds i see the picture on the moniter then it goes right out over and over again
    Genius:
  • 1,011 Answers
Ok,
remove the vga cable from pc and connect it again while running..
regards,
Posted on Aug 08, 2008
The text and pictures on my Kogi monitor are too big for the screen. How do I fit everything on the screen to the right size?
Sounds like your monitor isn't set up at the correct resolution.
If you're running Windows, go to your Control Panel and into Display > Screen Resolution.
Try setting it to 1024x768 or higher.
Mar 07, 2011 | Kogi L7CH Monitor
I have a Kogi 15"
This is the cord you're looking for. It's the same as the power cord for PCs. Only difference is the right end of the cable as that depends on which country you are in. You should be able to grab one of these at your nearest PC shop.
Mar 03, 2011 | Kogi Computers & Internet
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2...
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor ... it goes blank
Where can I buy the power cord for my KOGI L5QX?
Feb 09, 2008 | Kogi L7CH Monitor
Kogi lcd monitor L5BX
check the amp. settings on the power input.
Dec 23, 2007 | Kogi L7CH Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
57 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
