Konica Minolta Copier won't work at all.
I have a copier that just won't go. It was used quite OK 4 weeks ago and after coming home from holidays it just won't go at all. It appears not to be getting power. I tried replacing the lead etc and all else is OK. Power point is OK too.
  • lynny201 Feb 03, 2008
    The copier is a CSPro EP2010. I don't think it has a seperate power button on the control panel but I have tried holding down all the buttons for various amounts of time and none of them seem to do anything. I have taken off the panels on the back and had a look and can't see a breaker at all. All the wires look ok. It is not lighting up anything and therefore not showing any error code.
  • lynny201 Feb 05, 2008
    Drum and fusing section are good - no probs about the quality of copies etc. Only had the copier 12 months - bought it second hand. Copier has done 130,000 copies - don't know if that is a lot for the age of it or not but would like to get it fixed if I can. I will check out the parts you mentioned and go from there. Thanks for the help, much appreciated.
  • 1,326 Answers
What model is the copier? If it is a newer copier there is a main power switch on the side of the copier. Make sure that is "On" and then try the power botton on the control pannel. Also chk to see if it has a "Triped" breaker on the copier near where the power code goes in. Also dose the copier show a Error Code, if so what is it?
Posted on Feb 03, 2008
  • Chris Coughlin
    Chris Coughlin Feb 05, 2008
    You have a Minolta EP-2010. They have a in line fuse by the power cord. It should screw out and it is going to look like a fuse, but it is white and you can't see in to it. Use a meter set to ohms and chk to see if it blown, you should have no resistance over it or just a little. if you have have a lot of resistance. It may be blown. You can get a new one at Radio Shack. You could have a broken fusing heater lamp that is broken and the AC is getting grounded to the frame "shortting out" , also chk the fuse's on the power supply.One or all are blown and it can be the power supply it self. I think the problem is a pinched wire being shorted out. It may not be worth fixing, hows the drum and fusing section are they in good shape or shoot?
My yellow imaging unit is on back order, is there anyway to still use the printer until it gets here
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
May 05, 2015 | Konica Minolta Konica Bizhub C353 Drum...
PF-118/PF-119 Minolta Copier Wireless Download
DO the other computers on the network ok with the copier. Sir the copier you have is Di200/251/351. if so the best driver you mite find is for windows 95 or XP at best for that machine will not work with anything new. It is a legacy machine from Minolta now Konica Minolta. PF-118/119 are the paper draws for that machine not the copier! try below but doubt it. Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 22, 2013 | Minolta Office Equipment & Supplies
KONICA MINOLTA bizhub 601 problems
Does the machine work ok as a copier? Not as a Printer but a copier? if so then check you printer properties and insure that the paper is correct portrait or landscape, thickness correct draw check a different computer.
Dec 12, 2012 | Konica Minolta Developer 02xk Dv710 for...
Konica minolta bizhub pro 920 won't scan to email
have you log in to the copier via page scope and properly set up the scan to email info required, such port, mail server, authenication procedures
Nov 28, 2012 | Konica Minolta Konica Bizhub Pro 920 Toner...
Base e-mail on a Minolta copier C451
ok the best way to do that is through the WEB interface. use a computer that is pluged into the same network the copier is. then login as admin PW is 00000000 or 12345678 then click on the scan tab. then change the email that your looking for
Nov 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
I cannot print on local network to minolta di200 printer. The ping is 0k; the print test from admin webpage is ok. I used Pi3502_PCL_Win2kxp.exe
does the copier work as a copier? have you turn off/on the machine what print jobs are in the print q delete them check control panel properties of the printer. ok? di copier firmware may have courpted
Mar 12, 2010 | Konica Minolta DiALTA Di200 Copier
Display on bizhub 252 not working
switch main power off, hold down utility/counter while powering on then press trouble reset on the display, if this does not work you will have to re-flash the firmware, phase 3.05 is the latest (K0)
si
Jun 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
Mar 18, 2009 | Konica Minolta Di1610 Copier
101 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
