Question about Bush DVD142RC 14 in. TV/DVD Combo
Bush dvd tv combo 14" with 11 ak 46 chassis
Psu ticking with led pulsing .no faults found on primary side of psu
D805 is also ok.as is lineoutput transistor.
4 Suggested Answers
SOURCE: Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Posted on Oct 14, 2008
SOURCE: I need an instruction maunal for a Bush DVD142TV
download available at safemanuals.com (diplodocs)
Posted on Mar 23, 2009
57 varieties
  • 1653 Answers
SOURCE: CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Posted on Oct 03, 2009
I have a bush tv dvd combo le-32ge11e+dvd that has just stopped working ,I have changed the fuse and tried a different plug socket, but nothing not even the led on light ,any suggestions?
If your comfortable around higher DC voltages heck your hot side power supply and see if you have around 165 volts there if you do check the gate voltage of the FET and see if you have around 3 volts if you don't check the associated circuitry for the gate and source, if you do then go onto the cold side and see what voltages are bad but if nothing comes on (set dead) I'm guessing its a hot side issue
Oct 29, 2017 | Bush Televison & Video
Hitachi C2143S TV
you have a very unhappy tv...sounds like you have a relay clicking, or worse, something about to fail. the led pulsing is a warning signal, and going pure red means that you have a major failure inside the box.
you doing the service yourself, or open to a service pro coming in for this?
Mar 07, 2008 | Televison & Video
Bush good picture but no sound
This may help if the tv as a 3.5 ear phone socket try your earphones & see if the sound works if it do's then its prob the switch in the ear phone socket that's @ fault and norm inserting & pulling out the ear phone plug a few times can clear it
Sep 28, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine
Most Big box stores have a DVD cleaner disk, located in the electronics section, which is fairly inexpensive. I would try that first.
May 20, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine. does any clever person out there know how to fix this problem? would be very grateful
Laser pickup unit fault. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 14, 2012 | Bush DVD142RC 14 in. TV/DVD Combo
Mar 13, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Toshiba TV
Will not power, led blinking
check R640 (1K 1/4w) if open replace ic600 (8-759-670-30)
Standby led blinks slowly, a few times, chassis won't start up
I changed the vertical deflection ic type TDA8170 and I measured two leaky capacitors in the power supply. Better to change all 4 capacitors in the power unit, everything was then ok !
Nov 24, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
Ticking?
When this happens it is invariably the SMPSU, (Switched Mode Power Supply Unit), Generally the "Chopper" transistor has faulted. o you could either simply buy a complete PSU OR fix, replace, the faulty part. Then ya should be good to go.
Jul 15, 2007 | Philips 32PT9005D TV
Bush DVD142RC 14 in. TV/DVD Combo Logo
143 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
