Question about Navman ICN510 GPS Receiver
Bush tv/ dvd combo with 11 ak 46 chassis
Psu ticking no faults found in primary side of psu .Could it be eprom problem .Lineoutput transistor is also ok.
Bush good picture but no sound
This may help if the tv as a 3.5 ear phone socket try your earphones & see if the sound works if it do's then its prob the switch in the ear phone socket that's @ fault and norm inserting & pulling out the ear phone plug a few times can clear it
Sep 28, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
TV RCA THOMSON 27R411T CHASSIS ITC008FHM
Try replacing the eprom. If that somehow became corrupted due to HV surge or otherwise, you would have this symtom. The eprom contains information that basacally tells the HV circuit to turn on.
Apr 06, 2009 | RCA 27R411T 27" TV
I need an instruction maunal for a Bush DVD142TV
download available at safemanuals.com (diplodocs)
Mar 13, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
I have a panasonic quintrix tv tx28dk2. When i turn it on it turns itself straight onto to standby repeatedly.
The first thing I would check is the line output transistor this is the large transistor mount on the heat sink next to the lineoutput transformer (the big black thing with the lead going to the side of the tube) just replace it if you have no meter to check it.
May 25, 2008 | Panasonic Televison & Video
RCA, rear prjetion, 46" tv,no power, ticking sound
Ticking is usually related to the horizontal output and the flyback with the flyback being more suspect. If you need more assistance please let me know
May 13, 2008 | Televison & Video
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
Ticking?
When this happens it is invariably the SMPSU, (Switched Mode Power Supply Unit), Generally the "Chopper" transistor has faulted. o you could either simply buy a complete PSU OR fix, replace, the faulty part. Then ya should be good to go.
Jul 15, 2007 | Philips 32PT9005D TV
The lights on but no-one's home - no picture on TV
Sounds like you have a short somewhere, probably the Horizontal Output Transistor. If there is a fault the led you mentioned probably should be blinking. You probably are going to need a tech to look at this as it is a very complicated process of elimination.
Jun 19, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Navman ICN510 GPS Receiver Logo
146 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
