Question about Indesit W 123 Front Load Washer
Indesit WG635 TP power light on but not working
While my Indesit WG635TP washing machine was working tere was a sudden noice ("top"). The ower light went off. Replace the socket fuse and switched on again "Top" noice. But the power light is on nothing works. Front door can be opened. How tosolve the problem can some one gve me a solution please.
Frednavam@yahoo.com
  • 2 more comments
  • Fred Navam Feb 01, 2008
    Please let me know wher to find a wiring diagram for Indesit WG635TP washing machine. Also how the maching works when we power on the maching.
    Thanks.
    Fred
    While my Indesit WG635TP washing machine was working, there was a sudden blasting noise ("top"). The power light went off. Replaced the wall socket fuse and switched on again "Top" blasting noice. But the power light is on nothing is working. Front door can be opened. How to resolve the problem. Can some one guide me please.
  • Anonymous Apr 06, 2009
    its power is on but it wont wash and the door wont open
  • jorgerav May 12, 2009
    What program board is the Guru talking about??? WG635T
    Power light is on but machine not working. Door can be opened.
  • 417 Answers
Sorry program board my friend replace.
Thanks J
Posted on Feb 10, 2008
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
I have an Indesit washing machine. After it's been switched off and you Press power button, all light continuously flash won't even start any wash cycle
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 12, 2015 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
No power to my Indesit Washing Machine.
PCB has suffered a catastrophic failure due to the power cut, it will need to be replaced. if you have a power cut in the future always turn off your appliances, as the voltage can exceed the appliance recommended voltage. only leave a light on as lights can take the over voltage unless they are led type, you can but power drop sockets that when power is off it turns of the socket off so no power goes thought to the appliance.
Feb 01, 2018 | Indesit W 123 Front Load Washer
Indesit iwdc6125. All 5 top lights flashing and rinse and door lock lights are on. Does this mean the module needs programming?
The door lock is faulty. I removed the top cover and removed the red control box from its nylon casing on the lock. I then broke the locking mechanism. Leave the control box connected or it won't work. My machine works but no longer locks so could be a problem if you have small children.
Mar 29, 2012 | Indesit Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine W1A 121 no red light when
Select reset from front panel and reset timer. you may needalso to cure water level fault as its overfilling. could be dirty air hose to pressure switch...
Nov 13, 2009 | Washing Machines
LOUD NOICE AND JUMPING
IT seems that the wash drum is hitting on the exterior body possibly the shock absorbers have flattened out. Also the balancing liquid in the top inner portion of the wash drum has leaked out u will have to check the two
Oct 08, 2009 | Washing Machines
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
524 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
