Question about Frigidaire FRS26ZSG
Frigidaire model # FRS26ZSH/Control unit.
On the front of my Frig. the water & ice dispencer lost power, so I can not get the water or ice to work. Can you help me?
Down below in the product box, I can not find my model #!
6ya staff
SOURCE:
christian nielsen
  • 358 Answers
SOURCE: freezer freezing and refrigerator not cooling
When it build up ice in the freezer the cold air can't go through to the fridge , this could be because : the fan doesn't work. the unit is low in refrigerant or the defrost timer or heater are bad , if the fan works take off the back pannel inside the freezer and if is only cover with ice part of it and the rest of the coil is clear of ice ,it means that is low on refrigerant (it is a seal system so there's a leak and has to be repair and recharged with freon), but if the coil is all cover with ice the problem is with the defrost system(timer or heaters) you can check the heaters for continuity if open replaced it if ok replace the timer.
Posted on Aug 08, 2009
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Posted on Sep 19, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: I am getting NO water out of dispenser. The ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . If the line is frozen in the door , pt # WR49X10173 , is the dispensor water line heater , which comes with installation instructions .
Posted on Nov 18, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Posted on Jan 20, 2010
Doug Camburn
  • 122 Answers
SOURCE: 9-10 year old Frigidaire Gallery FRS26ZSH
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Posted on Jun 27, 2010
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire is not cooling
if able unplug for aout 3 minutes then plug back in (it should reset control unit) this should help
Jun 01, 2009 | Frigidaire FRS26R4A Side by Side...
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Unit stop producing ice
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Aug 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
169 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
