Question about Brother MFC 210C All-In-One InkJet Printer
Won't stop cleaning and using up all ink in cartridg
I'm continuing to have problems replacing ink. How can I reset printer so it will not go through cleaning every time I put a new cartridge in -- cleans cleans, cleans and then I'm left with a emply cartridge which leads to "ink empty" - continuing cycle over and over
Help --
I found a solution at another forum. I have the same printer with the same problem. What you need to do is put some electrical tape on the colour cartridges to stop the printer from sensing the ink level. I put tape on the clear plastic ridge on the back end of the cartridge and this allowed me to print from the black ink cartridge even though the colour ones were empty. I used black tape which i think would work best.
I am also going to leave the printer off until i need it so that it doesn't waste the ink by doing random cleaning at all times of the day.
Posted on Mar 28, 2008
  • 832 Answers
Just one advise: go buy another brand (canon).
brother printers cant be changed in the firmware. It does always cleaning cycles when one has changed the cart.
Posted on Feb 01, 2008
Canon mp390 manual
We suggest you first attempt the basic/universal Canon ink level reset procedures before attempting any of the more advanced procedures provided on our Inkjet411 site*
A. Standard Ink Level Reset Procedure (printers without LCD display):
[ Refer to the 1st support video: http://inkjet411.com/?page_id=62 ]
1) At computer screen message, select 'Stop'/'Reset', 'OK', or 'Resume'.
....or....
2) Select 'Stop'/'Reset', 'OK' or the 'Resume' button (triangle-circle icon) on your printer for 5-8 seconds:
- Printing may continue under the 'ink out' condition.
B. Standard Ink Level Reset Procedure (printers with LCD display):
[ Refer to the 2nd support video: http://inkjet411.com/?page_id=62 ]
1) Install cartridge and start print job.
2) After first message appears, click 'OK' to continue. Printer should start printing.
3) If second message appears and printer's LCD screen displays error code "E", then DO NOT click 'CANCEL PRINTING'.
4) Press and hold down 'Stop'/'Reset' button (triangle-circle icon) on your printer for 5-8 seconds. Printer should start printing.
If you are able to produce a self test print, this is good since it illustrates that the cartridges are electrically stable...if you observe any 'E' or 'V' error states (i.e. E13 or V162 for example), this may indicate there is possibly an internal electrical problem with one of the ink cartridges. Refer to your user guide if E/V error messages are displayed.
*If, after following the suggested ink monitoring/level reset procedures, you still have an error condition which prohibits regular printing, then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
To verify the Canon printer is functional, install a brand new cartridge in it - this will 100% confirm whether your refilled, compatible or remanufactured ink cartridge is faulty or not.
For information on North American Canon ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 12, 2013 | Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
Printer continually says put in cartridge even though I have (twice). I have checked over and over that the cartridge is firmly installed. Is there a sensor somewhere which needs cleaning or resetting?
Did you used refilled cartridge?
Sometimes for Canon printer, when u used refilled cartridges, they are not readable.
It's called E5 error.
In this case, you need to replace the cartridge with new one.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP170 with V051 error. Tried holding down stop/reset button but no result.
Hello thanks for using Fixya
To solve it:
Remove first the ink cartridges
.Then by using a cloth moistened with alcohol,clean the contact surface of the cartridge where the terminals inside the printer touches. Then return back to its carrier the black and color cartridges. Now restart the printer.
If error continue to appear. press and hold down the STOP/RESET button (the circle with inverted triangle button) Hold it down and wait until printer self restart before releasing it.
If it still exit
then it means ink cartridge is defective so
replace defective ink cartridge
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 22, 2011 | Canon PIXMA MP170 All-In-One InkJet...
E13 flashing up even though i have replaced ink cartridges
If you want to continue printing in this condition, press and hold the button on the printer for at least five seconds, and then release it.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jan 29, 2011 | Canon PIXMA MP210 InkJet Printer
Ink absorber replacement options - MP130 or how do I clean it? It is almost full according to error message
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
1. Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
2. When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
4. When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Power off the printer and Power it back on again to complete the reset.
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Mp160
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.try cleaning head just go to printer preferences go to find services and click clean head.
4.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement
Sep 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Pixma mx310: error message check ink u163 will not delete after replacing colour inkn cartridge cl 41. unable to use printer.
Ink has run out. Replace the ink cartridge and close the Scanning Unit (Printer Cover). If printing is in progress and you want to continue printing,press the Stop/Reset button for at least 5 seconds with the inkcartridge installed. Then printing can continue under the ink outcondition. The function for detecting the remaining ink level will be disabled. Replace the empty ink cartridge immediately after the printing.The resulting print quality is not satisfactory, if printing iscontinued under the ink out condition.
Thanks for using Fixya
source : http://support-au.canon.com.au/contents/AU/EN/8200172900.html#6
SAM ANDERSON
Sep 26, 2008 | Canon Office Equipment & Supplies
Wrong Cartridge Error Message
I have same problem.Please let me know if u find an anser
Feb 10, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
413 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
