Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic 47 inch rear projection
Hi my screen has gone a little darker than usual on my tv can you let me no what to look for to repair this i have been told that it common fault and that it needs to chips fitted in tv to solve this problem the tv man never even checked tv are turned it on so i am asking the exsperts thanks my email is frederick.cox86@yahoo.co.uk thank you
  • gpospish Feb 12, 2008
    I have the same problem. I looked at my lamps. There is a blue, green and red lamp. They all appear to be working. Should they be burnt out completely?
My TV screen is green with one other colour on some channel but on the music channel the blue is on the screen
Posted on Jun 06, 2008
    Scholar:
  • 86 Answers
Have you checked the lamps. Rear projection TV's have bright lamps, that can burn out. If you have had this TV for a while, that is the first thing I would check. If you still have to manual, it should tell you how to check the lamps and which ones you need to order.
These should be special lamps only Panasonic sells. Therefore they might cost a few bills.
Posted on Feb 01, 2008
Panasonic rear projection 47 inch
hi you are right this is common fault what needs replacing is the convergance ics theirs 2 of them but whils replacng these you will need any resistors checking for damage also as when the ics start to fail then its usually because a resistor has blown somewhere on the board causing the power to rise or fall and this causes the ics to fail
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Refurbishing the 1080i-capable Panasonic 47-inch WS DLP
The tubes have a useful life of 3000 hours. Replacing those tubes is close to $3000.00. It's going to be cheaper to get a smart flatscreen TV. The minute you try to clean the mirror, you will put tiny scratches on it. There is no bulb in tour TV, There are 3 cathode ray tubes. There is a lot of high voltage (25,00 or more) inside the TV, so be careful poking around inside the TV.
Jul 11, 2017 | Panasonic PT-47WX49 47" Rear Projection...
Burn marks in screen on my 47 inch pt- 47wx51ce
Hi, thank you for visit fix ya.
Can you provide me model number tv, please?.
Thank you
Sep 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX42 47 - Red color becomes prominent and screen goes blank when changing channels
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 20, 2017 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
