F9 code on unit. Attempted to use self clean feature and door is stuck locked. Sounds like it is trying to unlock but fails. All other features do not work. Tried checking wiring and unplugging unit but to no avail.
Yes, the error code F9 means that the door lock circuit is faulty and should be checked and replaced by a technician. I can supply you with a part number if your able to locate the model number. Which can be found usually on the inside of the pots and pans drawer at the bottom, OR on the back area or the stove. Usually will begin with letters followed by numbers. Hope this helps
Thanks
