Question about Metrologic Instruments 9520 Voyager
Metrologic USB Voyager scanner
I recently installed a USB voyager scanner. The scanner was working fine, however it only read 13digits. So i referred to the user manual and found the solution. However after doing this the barcode scanner stopped working. e.g. i scanned a product, it beeped however no digits appeared on screen or in notepad.
I then referred to the USB settings in the manual, and used the 'Enable USB Interface'.
This seemed to help, e.g. When i scanned a product details appeared in notepad however these details werent entirely correct. The code would appear 3times even after scanning once.
Is their another barcode or setting that i have to enable to resolve this?
Refer your scanner manual and scan the default barcode printed ,then scan the use interface barcode printed properly
Posted on Feb 02, 2008
Refer the manual and scan the default barcode and scan the usb interface barcode properly.
What is the proper cable for my MS9540 scanner?
Now Metrologic is under Honeywell AIDC
Voyager 9520 9540 Laser Scanner Hand Held Honeywell
If not mistaken,the USB cable P/N should be MX009-2MA7S
Jul 24, 2014 | Metrologic Instruments MS9540 Voyager...
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Problem with metrologic voyager on xp,
If your voyager has the new interface then you can, by reading a barcode, change the type of connection. You must also change the cable
Sep 04, 2009 | Microsoft Metrologic MS9520 Voyager...
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
MY METROLOGIC BAR CODE
What Is The Communication Method You used, usb or Kbw,
Aug 06, 2008 | Metrologic Instruments Metrologic Barcode...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Feb 14, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
880 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
