Question about Nespresso C190 Espresso Machine
Nespresso KRUPS FNA2 - red light blinking
The power went off my house, and the main fuse blew out. When resetting the fuse the red light on my Nespresso KRUPS FNA2 started blinking very fast and stays on. Any suggestion how to fix this.
Best regards
árni
  • noahaxeltige Apr 27, 2008
    I have actually the same problem and wonder how I kan fix it. Any suggetions. Thanks for your help.
    Regards
    Olivier.
  • Anonymous Feb 13, 2009
    Same problem
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
Samsung PN51d7000ffzxa Plasma Screen does not power on, Power light blinks RED
if the power supply is a new one and you follow the steps described,ther`s no doubt,the main board is bad. good luck! from Mexico City.
Jan 24, 2015 | Samsung Televison & Video
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
Power light blinks red but won't turn on
It sound as though you may have blown the power supply
Feb 02, 2010 | Pioneer PureVision PDP-502 50 in. Plasma...
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
Aug 22, 2009 | Televison & Video
Lights flash alternating between red lights and green lights
The EEprom (memory of the machine) has crash. Needs to be re-programmed or substituted.
May 18, 2009 | Krups Orchestro 889 Espresso Machine
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Tv will not light up.
Your main fuse blew if its dead but it could have caused other issues with an electrical spike when the power went off, this is kind of common..pull the back, replace the main fuse and see if it blows it again, if it does then the diodes in the hot side of the power board are bad and would need replacing.
Dec 09, 2017 | Televison & Video
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso C190 Espresso Machine Logo
993 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
