Question about Whirlpool 24 in. ADG6962iX Built-in Dishwasher
CODE F4 and washer not working
Hi we have a whirlpool dishwasher model No- ADG 6956 we have had it for 2 years and it has just stop working with code F4 on the display. Can you help.??
Matt
    Scholar:
  • 90 Answers
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Posted on Feb 03, 2008
My .Whirlpool ADG 7952 is showing F4 what is the problem please
remove front lower panel below door. paper with spec's and diagnostic procedures and codes should be there. is water on?
cause water valve can buzz if water no turned on under sink.
Jun 28, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Aqua Steam dishwasher, coming up for 3 years old, starts cycle but gets stuck with fault code F4. Have cleaned it out and persisted and it did drain but once again went to F4
You have actually posted your Dishwasher problem onto the (garment) Washing machine forum!
However I have checked my Whirlpool list for dishwashers and for some models 'F4' stands for 'drainage' (as you have checked) but for others it mentions (quote) 'no heat, relay, NTC (thermostat), connections, underfilling are all possible'(unquote).
When there is an NTC problem with washing machines we often suggest pouring the contents of a couple of boiling kettles into the washer as it sometimes kicks the NTC into life! Might be worth doing that with your dishwasher before calling for service ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi. I have a problem with my dishwasher ADG 6556.
If this model has the normal wash, and heated dry buttons there is a sequence of buttons to press to do the reset, which buttons do you have, reading from left, to right on the touch panel.
Dec 29, 2010 | Whirlpool Dishwashers
Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
Hello Sir,
This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Whirlpool WFW8300SW
Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 04, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 24 in. ADG6962iX Built-in Dishwasher Logo
540 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
