Question about Garmin 60 GPS Receiver
System date and time are wrong
After recent repairs, the system date and time are wrong. How do I reset them?
  • Anonymous Mar 04, 2008
    I just got a GPS 60, and the date and time are wrong! I know how to switch time zones, but I'm on the right zone, and the date is 2 days off!
Go to the tesk bar and double click on date icon and set correct time
Posted on Feb 03, 2008
Divx vod registration code
its an paid app
try to install a trial version
and run in the trial period only
after trial period expire
reset your system timing in that period only
eg:
you activated trial version on 01/01/2014
valid for one month
then after every month as date become30/01/2014
set your date back to 01/01/2014
your divx will work but system will show wrong date
and you cant run opera or web
Jan 26, 2014 | Cell Phones
Cannot sign in, continually get the following message..Something went wrong and we can't sign you in right now. Please try again later.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Sep 12, 2013 | Computers & Internet
System settings were lost
System settings were lost:
You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
Press the A Button to display Calendar Menu choices of Date or Time.
Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
Press the A Button to accept your choice.
Press the B Button to return to the Calendar Menu or the Main Menu.
Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
Wrong Game Disc:
This message happens when a Game Disc has been removed while the system is on, and a different Game Disc is inserted. Re-insert the original Game Disc.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Nov 17, 2012 | Nintendo Wii Console
I have a PC with windows 7 32 bit , suddenly couldn't boot , when i try to repair using the windows 7 CD it says that i have an other system than the one installed on the Hard drive , i think because i had...
Try to boot in safe mode-start tapping f8 on start-if ok see problems&solution center.If nothing there then go to add/remove programs and take out sp. Something went wrong.If you cannot boot in safe mode then you will have to restore windows.Try to restore windows on the date before you install service pack.
Nov 23, 2010 | Computers & Internet
Cannot access my yahoo mail website
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please open Internet explorer.
go to tools menu..advanced tab...clcik the reset button
click apply and ok
close IE and then reopen and check
if this is recent problem..try a system restore
the system restore should reverse any changes to the system that might have caused the issue to occour.
click start...in the search box type system restore
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
Nov 21, 2010 | Yahoo Mail
System date error! please check NDS system date
It's a bug issue in the firmware of the R4 cards. Won't work after 14 april 2010 unless you update the firmware of the R4 card.
For the time being you can set back the date before 14 april 2010 and it wil work directly.
gr
Apr 19, 2010 | Nintendo DS Lite Console
How to restore computer during boot up?
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Jan 12, 2010 | Acer Aspire 3050-1733 Notebook
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Will show avaliable wireless networks but won't connect
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
if the Issue presist then you need to try System restore
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page(try the date 2 dats prior it was working or the First Bolded Date of that month), click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK.
Aug 09, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Garmin 60 GPS Receiver Logo
560 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
