HI. This error code will occur when the control board senses an oven temperature above 915F-935F
Once this type of temperatures occur, this will generally weld the relay contacts on the main board. This will damage the board, and it will require you to have it replaced, asap. If these temperatures never reached the sated thresholds, i would advise to Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace the sensor if found to be defective. Check door lock switches for damage, as well.
In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature..
SOURCE: F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
SOURCE: Oven continues to beep. On the display it reads "F2"
HI. this F-2 is a code that represents a oven temp that is way to high and it is not registering on the oven temp.
1. Look for welded
relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high
harness connection at sensor and oven control. Replace sensor if found
defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
