Question about Clarion DRX-9675Z CD Player
Clarion drx9675z head unit connector
Where can i purchase a wire connector for the drx9675z head unit? 8 pin white connector next to a square black connector.
  • 111 Answers
Go to pacparts.com
They are authorize parts dist. for Clarion
Posted on Feb 01, 2008
What is the sqare chuck , wires two black and two white wires on the motherboard ?
Boy, ya got me.
If it was a small square opaque white socket on the motherboard, that a power cable from the Power Supply; had two YELLOW wires, and two Black wires, and plugged into it, I would know what it is,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
As technology for personal computers advanced, hardware components needed more power.
The motherboard wasn't able to deliver the power needed, so the 4-pin ATX +12 Volt power cable, was brought out.
More power was needed later.
Hardware components demanded more power, than a 4-pin ATX +12 Volt power cable could deliver.
So the 8-pin EPS +12 Volt power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
It CONNECTS to the motherboard. (For motherboards that use one)
NOT to be confused with the 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
This power cable plugs into a GRAPHICS CARD, not the motherboard. Note the color code of the wires.
For a PCI Express expansion slot on the motherboard, for a graphics card; the best the PCI Express slot can deliver is 75 Watts.
The 6-pin PCI Express power cable was brought out next,
It is plugged into the graphics card too, and can deliver up to an additional 75 Watts.
Now there is 150 Watts available for the graphics card.
Computer technology advanced, and the 6-pin PCI Express power cable, couldn't deliver the power needed.
Now comes the 8-pin EPS +12 Volt power cable.
The 8-pin EPS +12 Volt power cable by itself, can deliver up to an additional 150 Watts.
Now there is 225 Watts available for a graphics card.
75 Watts from the motherboard, 150 Watts from the 8-pin EPS +12 Volt power cable.
Color code of wires;
1) Orange = 3.3 Volts
2) Red = 5 Volts
3) Yellow = 12 Volts
ALL are DC Voltage
(Two flashlight batteries produce 3 Volts DC)
4) Black wires are Ground wires. Also are known as Negative wires.
This motherboard happen to have a manufacturer name, and Model Number?
Can't find it?
How about the computer manufacturer name, and model number, it came out of?
The model number for a desktop computer, is on the back of the computer, next to the Windows product key; or up on the side of the computer tower.
(The plastic front of a desktop computer is the Front Panel.
Some older computers had a Door in the Front Panel.
The door is opened, and you look inside -> Down, for the model number)
Post back in a Comment.
Regards,
joecoolvette
Feb 08, 2013 | Computers & Internet
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
I need a wiring diagram to hook up a new radio.
First you will need to get a wire harness for your specific make, model & year of car. This will interface the car wiring plug to your new clarion headunit.
Next you will connect the wires from your purchased wire harness to the wires of your Clarion Headunit. Using **** connectors with a wire crimper is the best way to do so.
Here is a wire color coding guide for the wires on your Clarion headunit:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Clarion Car Audio & Video
I dont have a diagram for my clarion drb4475 wires. can you tell me what each wire is for?
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Blackedd1c80.gif
Mar 27, 2010 | Clarion DRB4475
In need a wiring diagram for a clarion vrx745vd head unit
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Aug 30, 2009 | Clarion VRX745VD Car DVD Player
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wireing harness.
Hi diamante,
For your reference, pls see below image.
Further, here is a page of the official Clarion standard wirings and their color codes.
Here is a source of the connector for your reference. You don’t need the speaker connector since your unit does not have any built-in amps.
Additionally, if your vehicle’s wiring connections are not of the ISO-standard type or if you just want to verify, please follow this link for the installation adapters you may need to fit your Clarion DRX-9675Z CD Player to your particular vehicle.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | Clarion DRX-9675Z CD Player
Manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jun 20, 2007 | Clarion DRB2475
No sound
It's very likely that you have a factory amplifier in the vehicle that needs to be either turned on or (preferably) bypassed to get sound to the speakers. If your vehicle is a Mustang, it's almost certain that you have a factory amp. If the factory plug includes a long, 8-pin gray plug and a small, square 8-pin plug connected to a round cable, then the amp turn-on wire is at the opposite end of the gray plug from the constant power wire. This needs to be connected to the blue/white wire on the Sony head unit for the factory amp to turn on. Otherwise, if you dig into the radio cavity a little bit, you'll find a black 8-pin connector that looks very similar to the gray connector at the back of the radio. The black connector pins are connected directly to the speakers, bypassing the factory amp.
Mar 15, 2007 | Sony CDX-2250 CD Changer
Clarion DRX-9675Z CD Player Logo
352 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
