I have no picture or sound when iturn t.v.on iunplugedand let set about 10 minutes and have same problem
    President:
  • 1,944 Answers
When you turn you TV on, does anything happen? What is your TV brand and model. Thanks.
Posted on Feb 01, 2008
    Brigadier General:
  • 6,966 Answers
Most current designs of TVs would need a couple of hours unplugged before it would reset itself to default settings. There are some instances that overnight would be better.
If this proves to be not corrective, please post back with the brand and model of your TV.
Hope this be of initial help/idea. Pls post back how things turned up, details as requested or should you need additional information. It would also be of help if you can post any indicators such as blinking lights (LEDs) colors, their blinking sequence and anything else out of the ordinary.
Good luck and kind regards.
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Picture goes black but sound is good after tv is on for 10 minutes, please help
Please check if exchancing powercord helps and preferably to other power connection.
Do check your signal generating device
Antenna - RF ?
Set top box (Cable or satelite)
DVD or VCR for broken connection.
They could be the cause also and not the TV.
A broken soldering on a euroscart connectort is treaseurous on a VCR or so. I open those up and check scart connectort on board solderings or check cable for loose connections.
If nothing there or you not technical enough call in a handy guy from the block before cleaned out.
Pls do not open your TV set, that gets ugly.
You like my advice, rate me, i am doing my best
May 06, 2009 | RCA HD52W59 HDTV Projection Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Blinking screen then...
Sorry, your CRT is bad.......rejuvenation might help,
replacement of tube not practical.....best solution..replace set...
Dec 06, 2007 | Sony KV-32S45 32" TV
Picture goes dead after 5-10 minutes
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Mar 03, 2007 | RCA 27F530T 27" TV
SOUND BUT NO PICTURE
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Dec 24, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
