Question about Intel Motherboard
Msi mega 180 problem
Everytime i boot, after loading windows, my monitor turns black.
i have to press F8 while booting and choose enable VGA to enter windows xp.
i think i have a problem with my video card.
i tried the safe mode and got no problem.
any suggestions?
thanks in advance.
  • 689 Answers
Reinstall your Graphic card driver. If you dont have the driver please post for driver request.
Good Luck
Posted on Feb 01, 2008
6ya staff
SOURCE:
Everytime i turn my inpiron1525 on it goes to a black screen and does nothing how do i get it to start up
hi there,
Try pressing f8 key to get the advance boot options, try booting the system in safe mode. It will be too slow to load your profile.
Now as it loads, it might give error message that your system has recovered form serious error.
Now shutdow, boot the system in regular mode. It works.
Else it may also be a display problem, for that choose VGA mode after you press f8.
Let me know if it worked.
Rate this solution and comment to keep in touch.
WisBee
Sep 22, 2010 | Computers & Internet
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Switch on computer tower and screen. Screen brings up LG logo and 'Activating power saving' then the screen shuts down. The tower continues to load Windows etc but I can't see a thing as the screen is...
For that when you power up the computer press F8 key then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then restart computer then it fix errors .
If still not able to see windows then again press F8 then enter in enabler vga mode then go to display property and change screen resolution to 1024*768 then apply and ok then check.
If still same then you need windows disk boot computer with that disk.
When you power up the computer press F1 or F2 or "del" key then enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then it boot with that disk.
Follow the procedure and enter in recovery console then type "chkdsk /r" then it fix errors on harddrive then after completion restart it again boot and this time choose "repair previous windows" then it repairs it then you can use windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 22, 2010 | Computers & Internet
Starts up fine, gets to win xp loading screen and then goes black, i cannot get into windows, plz help
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in enable vga mode.
Then go to start menu then control panel ->dispaly ->settings.
Also make sure that graphic driver installed and working fine.
change screen resolution to 1024*768 then apply and ok.
then check in normally.
But if you are not able to see even safe mode then you need recovery disk or windows disk.
Boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot menu then set first boot device as cd/dvd rom .then save and exit.
Thern it boot with disk.
Then follow the procedure and repair your previous windows.
Let me kno wif you need further assistance.
Nov 10, 2009 | MSI K9MM-V Motherboard
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
thanks
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Resolution is too high
You need to start the computer in VGA mode. To do that, turn on the computer. Keep pressing the F8 key every second until a boot menu appears. Select enable VGA mode. The computer will boot to a 640 x 480 resolution. From there you can go to your graphics properties and select a more suitable resolution for your monitor.
Jul 04, 2008 | Gateway GT5028 PC Desktop
Intel Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
