Subwoofer for Teac AG-D8800 Receiver
Hi, i am currently using Panasonic HTIB (with 2 fronts, 2 rears, 1 center and 1 subwoofer speaker) and thinking of upgrading the sound by buying a Teac AG-D8800 Receiver and A DVD player to replace it. As my rear specker is wall mounted, i would like to keep the existing speakers. However, i understand that my subwoofer is not suitable for Teac AG-D8800. Thus, i would really appreciate if you can advise me on what type of subwoffer is suitable for it. Pls also recomment the brand and model of the subwoofer.
A Home Theatre Novice
To tell you the truth, if you want to upgrade, upgrade the speakers. Speakers are the single most important component to good sound.
The key word is efficiency...
As a professional sound engineer I can tell you this: wattage, as used as a comparison tool, is nothing. Speaker sensitivity is the important spec. Note this. A speaker that is rated at 300 watts, but the sensitivity is rated at 90 db is actually considerably lower than a speaker rated at 100 watts but the sensitivity is 94 db. This also means you do not have to spend as much money for an amplifier that has a high wattage rating.
Things like frequency response, etc are mildly important, but as I suggest to anyone is how the sound is to you. When making any audio purchase, take music you are familiar with...
jeff
Posted on Feb 05, 2008
  • 107 Answers
Speakers are suitable to any amplifier, exept for the rating of it. (wattage) sometimes there are some speakers that are voltage needed. well you can use it as a subwoofer output for your tv for better sound.
just buy a aux splitter for the two amplifier, so that you could use them both.
hope I helped you for this.. have funn.^^
Posted on Feb 02, 2008
Sorry, I would like to know if you connect the rear L/R speakers to the back of the subwoofer will it work??? Thanks
That would depend on the subwoofer and its connections, wouldn't it? What does the unidentified sub's manual say?
If the sub is just receiving LFE you wouldn't magically get L/R Rear out of it. Manuals.
Sep 05, 2011 | Teac AG-D7900 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Wiring speakers
your main 2 speakers (front left & right)..hopefully the 5th speaker is a subwoofer right if not it will be...the last 2 speakers will be use as the rear (left & right)...in order for this to sound correct the receiver should have a button (5:1) depressed ...otherwise you just have 5 regular speakers...
Jun 24, 2010 | Denon AVR-1400 Receiver
Rear speakers L and R not working
if its a 5.1 channel home theater,it means you have to hook up the subwoofer or maybe a center speaker to its terminal to have them all working. 2 front speaker,2 rear speaker and 1 center speaker or subwoofer =5 and amplifier is 1 so it is a 5.1 channel.hope this help..
May 31, 2010 | Sony STR-DB940 Receiver
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
What speakers are beneficial with this receiver? I want to have surround sound from my TV and also from my other components - CDs and old record player.
Well to get the full effect of 5.1 surround you will need 2 front speakers, 1 subwoofer, and 2 rear speakers. Personally I used 2 tower speakers, 2 rear speakers and a subwoofer. Match the speakers with the RMS wattage of your Receiver. (100x5) or roughly 50 watts per speaker. Yamaha, KLH, Philips are pretty good speakers.
May 13, 2009 | KLH R5100 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
478 people viewed this question
 Grubhead
Grubhead
