Question about Quinny Buzz Jogger
Buzz height adjustment button
My Buzz height adjustment button keeps Jamming, so I cant press it in at all to adjust the handle or release the auto unfold. I have sent it back twice for repairs and I got it back today and it Jammes up while in the store and the sales lady forced it loose adn told me it is a safety locking mechanism so you cant accidently press the button, is this true?
  • 8 Answers
You can buy a new one pretty cheap phone dorel on 01842763281 easy to change as i had to replace mine
Posted on Oct 04, 2008
  • j wid Aug 17, 2011
    _________Quinnysales_________
    I repair these handles I only charge £40 for that you get new cables and new grips !!!!
    Same day service
    Call jef on 07886531199
    Ps new handles wil not fit older models
    Same day service
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
I need the handlebar wires that make the height adjustable handle work on the quinny buzz 3 any ideas?
Hi - The wire from inside the Quinny Buzz handlebar isn't available as a seperate spare part item. To replace it, the entire handlebar is required, which comes complete with the inner workings. How old is your Buzz? If it is under 2 years old, please contact your retailer with your proof of purchase to make a claim under the terms and conditions of the warranty. If it is over 2 years old or you do not have proof of purchase please contact the customer service department for your country - for the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Nov 28, 2011 | Quinny Buzz 3 Stroller
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
Jul 10, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
I can't fold it
If the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. HTH
Jun 30, 2010 | Quinny Freestyle 3 XL Stroller
How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
Feb 03, 2010 | Quinny Buzz Jogger
I need the instructions for alarm clock model number cc208s
Please try this....
Setting the Clock
1. Press and hold the Clk Set Button.
2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
3. Release the Clk Set Button to set the time.
Setting the Alarm
1. Press and hold the Alm Set Button.
2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
3. Release the Alm Set Button to set the time.
4. Adjust the Auto/Off/On Button to Auto.
5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
Cheers!
Jul 13, 2009 | Audio Players & Recorders
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
How do you unfold and fold a quinny buzz
Hi to unfold undo the clip if there is 1, some don't have them. lift the handle slightly then it should unfold it self.
To fold you need to apply the brake, stand in frnt then the 2 large grey buttons either side of seat, 1 pushes in 1 comes forward, do this & pull down towards your feet this will fold it up. Don't mistake the small grey buttons on side of seat they are to lay seat back/forwrsd etc; the large buttons are on the frame.
Oct 08, 2008 | Quinny Buzz Jogger
Quinny Buzz stroller
The base fits into the two adapters on the chassis, then once fitted you can chage seat position by pushing down the two buttons on either side of the seat unit you can move the seat up and down as you want. Also to unfold you simply push the button in the middle of the handlebar (the same button you use to adjust the height of the handlebar) you hold this button in and sort of give it a little shake and the chassis should unfold pretty much by itself and sort of 'pops up.'
Apr 25, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
154 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
