Question about Philips GoGear HDD6330 MP3 Player
It keeps say plug mp3 back t pc
I have formatted and tried syncing it and every time i unplug it after sync it says pease connect player to pc everytime
  • 8,596 Answers
First, try resetting the GoGear by pressing the Power on/off and Volume + buttons simulataneously and holding them (preferably do this when the player is on; the reset is successful when the player shuts off).
If that fails, Back up all the files on the GoGear and perform a Repair:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
In the future, even though it's a pain, use Windows' "Safley Remove Hardware" feature to safely remove the GoGear from the computer before disconnecting.
Also, see the warning on Philips website about Windows Media Player 11 and this device.
-Tha Mp3 Doctor
Posted on Feb 04, 2008
Boot error on mp3 player model 4008a
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jul 04, 2008 | RCA OPAL M4001 MP3 Player
Ilo mp3 player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 12, 2008 | iLO (2 GB) MP3 Player
Ilo MP3 player locks up when plugged into MAC or PC
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 05, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player will not power on
2)
Mar 02, 2008 | iLO (2 GB) MP3 Player
MyMusix PD-6030 MP3
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
You may also want to check www.mymusix.com for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Feb 12, 2008 | MyMusix PD-6030 MP3 Player
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
Scandisk 1gb
There could be several issues here.
Is the computer showing the Sansa as plugged in?
Does Windows Media Player show the Sansa as plugged in, or does WMP say "Please Connect a Device"?
Are you running Windows Vista or windows Media Player 11? If so, grab the Firmware update from Sansa's website at: http://www.sandisk.com/Retail/DriverDownloads.aspx
If the player keeps freezing while plugged into the computer, you may need to Format the player in Windows Media Player 11 after performing the firmware upgrade. This will erase all of your songs off the player, so you will have to reload them. But your player will work fine after that.
Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jan 15, 2008 | SanDisk Sansa c200 MP3 Player
I think my Sansa has a virus
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Jan 08, 2008 | SanDisk Sansa E280 MP3 Player
Ilo mp3. incorrect fomatt reformatt the player.
Plugging it into your friend's pc cause the player to be reformatted in a way that it no longer likes your computer.
-Tha Mp3 Doctor
Jul 28, 2007 | iLO (2 GB) MP3 Player
Need help for my iriver h10 5gb
-Tha Mp3 Doctor
Aug 16, 2006 | iRiver H10 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
