Question about LG GWA-4082N DVD RW Dual Layer Burner
Gateway laptop dvd drive promblem
Am having a problem with my laptop, recently it does not read any cd. the device manager shows a yellow question mark on that driver and it says Code 39 has been corrupted
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Ok you need to completely remove the cdrw from the pc remove all software (turn your pc off ) reboot it with out it ,then reboot it with the cdrw in it and go to add and remove hardware in your control panel and add driver when it asks and i think it will work correctally lala linda
Posted on Jun 03, 2008
I have a notebook gateway nx570x im having problem wiht my cd-rom/dvd dont read or play anything....help!
could be a registry problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 09, 2011 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Gateway NV53 win 7 64bit //the dvd-super multi dl driver stop read dvd/// cd
Click start control panel system and security system device manager, management, scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel system and security scroll to sytem tab you will see device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 24, 2011 | Gateway (5500652) (  5500652)...
DVD ROM CAN'T READ ANY DISC, I ONLY CAN BURN CD'S TROUGH ITUNES BUT I CAN'T BURN DVD
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 18, 2011 | Gateway (5500652) (  5500652)...
I have a Gateway NV52 and the CD/DVD drive doesn't work. It worked fine for a short time, but suddenly stopped reading discs. It tries to find data on the inserted discs, but eventually just pops out the...
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Apr 30, 2011 | Gateway (5500652) (  5500652)...
I have a gateway laptop model m-6866 and all of a suden my cd/dvd drive is not working. Suggestions please.It closes and opens but when I insert the cd/dvd othing happens.In my device manager the cd...
Your CD/DVD drive may be fine, but some software is faulty. The repair is a very similar process for all Windows versions, which involves editing the registry, so use caution. Here's a my search results:
repair registry for dvd drive Google Search
as well as a link with repair instructions:
https://itstillworks.com/12171166/how-to-use-the-windows-registry-to-fix-a-dvd-drive
Dec 06, 2017 | Gateway M-6866 Notebook
My cd rom is not reading i think it is missing a driver
The yellow triangle is signifying that there is a problem with the drive. Usually it is a driver that has gotten corrupted. Try uninstalling the drive in your device manager then reboot. See if Windows reinstalls the drive automatically. 99% of the time this will fix the problem. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Acer (4432A-002) CD-RW Burner
My dvd rom drive won't read any disks
The yellow exclamation point in the device manager means there is a problem with the drive. It could something as simple as installing a driver for the drive or it could be that the drive is bad. Hope this helps & please rate my answer. Thanks.
Dec 28, 2008 | Pioneer DVR-107D DVD±RW Burner
DVD doesn't open
This problem may be a bad cd/dvd drive. When the computer boots up, go into the BIOS setup. Check to see if the computer recognizes the drive, and make sure it is not disabled. Next, check in the "device manager" to see if there are any yellow question marks or red X's. This might indicate a driver problem, or a misconfigured drive. If these steps fail to resolve your problem, replacing the drive would be your next step. This is a fairly easy task, and worth the time to research the steps for your particular model.
Nov 15, 2008 | Gateway MT3705 Notebook
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
LG GWA-4082N DVD RW Dual Layer Burner Logo
515 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
