Question about Hitachi 53UDX10B 53" Rear Projection Television
Reset Magic Focus
After trying to do Dcam convergence, I lost Magic Focus. I was told to go back to Dcam then to press PIP Mode then CC to initialize the sensors for MF. To get back to Dcam, I have to press the 'magical' blue button. Exactly where is the blue button? Thanks.
  • jerry lembeck Feb 17, 2008
    I push magic focus and blue and red crosses come up not the focus. what to do
    President:
  • 4,402 Answers
I think your problem might be Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Feb 06, 2008
6ya staff
SOURCE:
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
DOUBLE IMAGE HITACHI ULTRAVISION TV
Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
Oct 27, 2008 | Televison & Video
Convergence ICs
Well if you are not a repairman you should not do this kind of job yourself.
If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
Check this link here to find sellers for the kit and illustrated procedures.
Here I am reporting convergence procedure from website above.:
" Manual Convergence for the Hitachi
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
to make sure the magic focus still works (and that you did the last few steps properly)"
Perform full convergence procedure before replacing ICs.
To know if an IC has blown you should test the small fuse at the base of the IC.
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Convergence
Can you explain the problem in a little more detail please? also make and model of the tv.
Thanks,
Lee
Jul 12, 2008 | Televison & Video
Hitachi 43F300
reset the projectorsettings
Jun 23, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Adjust the color in a hitachi 43F300
The below convergence procedure was copied from: http://www.espnhd.com/voice/showthread.php?t=3736
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
Hope this helps
Dec 15, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
165 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
