Question about Nikon Coolpix P1 Digital Camera
Lens would no move Nikon Coolpix P1
I need help, my Nikon Coolpix P1 's Lens would not move at all. I think it must be something wrong with the gear which prevent from lens' movement. Please help me out
Thank you
Did you send shop repair problem Lens??
Posted on May 20, 2008
When i turn my nikon coolpix 6500 on a message appears saying lens error and lens stays closed
Something wrong inside,your camera's gear system..maybe it stuck.go to the nearest service center for help...Dods
Sep 28, 2013 | Nikon COOLPIX Cameras
Lens error shows up when you turn on camera and lens won't open
This occurs when the spring inside the lens is out of place. Then, the lens is unable to move and autofocus, causing lens error. It is practically impossible to repair it yourself. You will only make it worse if you are not a trained professional. I have tried it myself on my Nikon P1 camera.
The best thing you can do is to take it to a service center for repairing. If the camera is under guarantee, then repairs will be free. If it is not under warranty, you can expect to pay under $50.
Cheers
May 02, 2011 | Nikon Coolpix P1 Digital Camera
My battery has went dead and when I went to charge it. It wouldnt charge at all. Plus, when it was working and I would go to take pictures, it would sound as if something was loose in the lens.
If your Nikon EN-EL10 battery for your Coolpix S4000 won't be charged, there seems something wrong with your battery or battery charger, so you need a new one. The problem about lens, if something was loose, there maybe a screw and after a term it may cause lens error.
Feb 08, 2011 | Nikon Coolpix S4000 Digital Camera
Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Apr 19, 2010 | Nikon COOLPIX L18 Digital Camera
I dropped my Nikon Coolpix S600 camera on the floor at a concert and now when I turn it on, it says LENSE ERROR and shuts off right away.. and the lens doesnt come out. It just makes a weird noise! Is it...
there are some fine gears that move the lens in/out ... if it dropped on the extended lens then its likely a gear was broken or knocked out of place .. it is likely repairable but its really tricky working on these things .. there are fine wires and delecate stuff inside.. sometimes a particle will get into the gears and keep them from operating .. if thats the case you can try gently moving the lens around to try to free it .. but unless you can find someone familiar with working on this then i think you need a new camera ..one with a strap ..
Aug 01, 2009 | Nikon Coolpix S600 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
LENS ERROR
My Nikon L14 Camera Is Showing Up Lens Error
Can Someone Please Help Me.
Aug 22, 2008 | Nikon Coolpix L14 Digital Camera
I get a "lens error" every time I switch my Nikon Coolpix P1 camera on. The lens won't open or extend out.
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jul 29, 2008 | Nikon Cameras
Lens Error
sir i think ur camera droped, internal unit dislocated or gears problum this is repairable
Apr 06, 2008 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix P1 Digital Camera Logo
136 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
