Question about JVC SR-DVM70 DVD Recorder
Dubbing to DVD not working
I am unable to dub from my HDD to a DVD. A message appears that says "change the recordable disc ". I have tried using new DVD's as well as pre recorded ones but the problem remains. Can you help?>
  • locationx3 Nov 30, 2008
    did you ever find a fix for the sr dvm70? it sounds like i have the same or close problem .
    used to go thru lots of "can not dub to this disc " till one in 25 disc's would work ,now it just wont dub from hdd to disc
I am from Sri Lanka.I have JVC SR-DVM70, DV/HDD/DVD Recorder,This Player canot Record(dub) DVD.(From HDD to DVD,DV to DVD).I checked DVD RAM connect to PC and Record DVD.It's Ok.DVD drive is good.but JVC player canot record DVD's ?Pleas given solution my problem.
Posted on Jun 11, 2008
Make sure the DVD is formated.
Posted on Apr 10, 2008
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
DVD Record wont finalize - LG RH397D
Have you changed brand of disks? Sometime different brands give different results.
Aug 08, 2009 | LG DR787T DVD Recorder
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
Can not get dubbing to work
Samsung's solution to many problems seem to be the type of dvd. Try using a dvd-r. I am able to select dubbing with a dvd+r, but the +r discs won't play in other dvd players. Apparently, -r is the only disc to use with this box to avoid issues. The +r records the soundtrack a few seconds off of the video track.
Dec 14, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Norm
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Jan 22, 2008 | LG RH-4820 DVD Recorder
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=DVDFirmware , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
JVC SR-DVM70 DVD Recorder Logo
364 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
