Question about FireLite (USBFLB80) Hard Drive
Firelite HD 160GB won't mount on PC
Hi Experts,
My Firelite portable FW HD works fine on the mac, but I was hoping it would also mount on my PC. Is it possible to run the HD on both. I had a LACIE that worked on both systems. I'm running OSX 10.4 and windows XP?
Cheers if you can help.
  • reginald_t Jul 11, 2008
    My Firelite HD Model #USBFLB40-C won't mount on my iBook running MacĀ
    OS X Version 10.4.11. How can I fix this problem.
    Thanks
    Scholar:
  • 58 Answers
Try this site: http://sewelldirect.com/USBManualShareSwitch2To1.asp. Although you must purchase this "splitter", you can use the Hard drive on two different computers. CAREFUL! Make sure that only ONE computer is reading or writing to the same file at a time! If you have a crossover, the hard drive could crash!
Posted on Feb 11, 2008
USB DRIVE IS NOT DETECTED.
you may have to download a driver for it, but do check that all leads work find and you usb 2.0 and 1.1 connections are working fine too, cheers
Dec 12, 2009 | Verbatim 160GB USB FireLite: The "drive...
I just installed verbatim 250 gb hard portable hard drive How do I get the files I want backed up to save to the drive. No Instructions
there should be a disk that has backup software on it that came with the HD.
if you just want to do simple back up just open up Mycomputer or windows explorer addn drag files to the new hd, like the my documents folder.
Oct 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
Jun 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
Verbatim 160 GB portable hard drive doesnt want to open IbookG4
must be usb, usually if you have other devices using this resource and have not closed them it will not work. close all then add hardware, follow the rest it should work.
Apr 24, 2009 | Verbatim 160GB USB FireLite: The "drive...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
FireLite (USBFLB80) Hard Drive Logo
139 people viewed this question
Top FireLite Computers & Internet Experts
Paul Bade
tdk1988
John Anderson
John Anderson
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
