GREEN CONVERGENCE IS MOVED,I THINK I CAN FIX FROM SERVICE MENU,CAN SOME ONE TELL ME HOT TO ACCESS IT?SAMSUNG PROJECTION TV HCN 4226W.
Can some one tell me how to access the service menu on my projectio tv SAMSUNG HCN 4226W? I NEED TO ADJUST THE GREEN CONVERGENCE ON MY TV.THANKS.
1. Go to Picture section
2. Scroll down
3. More menu option appear
4. Then pick 'convergence' on the list
5. push remote right key
Then you're at the convergence menu.
Posted on Mar 02, 2008
    Problem Solver:
I thought that it was just menu/settings/convergence. Good luck.
Posted on Feb 01, 2008
RCA D52W23: Only partial convergence menu. I can only access Autoconvergence, Red and Blue convergence options (not Level 1, 2, 3, etc.) in the service menu. The picture is only slightly off (i.e. green...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2011 | RCA D52W23 52" HDTV CRT TV
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
When i turned on the tv the convergence was way off.I was able to fix the red and blue but the green cross hair has moved 2 inches over and in the middle the is wavy please let me know if there is a way to...
If auto convergence does not work in the menu then replace the convergence ICs and check resistors around it. You can take the grill off the front and access the convergence board fron the front. Its a small board to the right and it is removable. Do auto convergence again after replacement.
Mar 25, 2010 | JVC AV-56WP30 56" Rear Projection...
I have a 65' Samsung model #HCN-653W rear projection tv... just recently the picture became distorted as if watchingsomething that is 3D... Is it a tube or something that I can replace with out getting to...
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Feb 23, 2010 | Samsung PCL541R 54" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
Could you tell me how to get into the service menu of my toshiba rear projection tv?
Most TV repair shops have a warranty 30, 60, or 90 days. Call him back. You probably have a convergence IC failing or a resistor changing value in the green convergence output circuit.
Jun 04, 2008 | Toshiba 57H81 57" Rear Projection...
Convergence amps blown
If you buy the entire assembly is just plug and play but you might still have to make the adjustments manually if the auto/magic focus does not work.
Good Luck with your venture.
Apr 11, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Samsung sp43w6hpx/xeu
Convergence is out. Go to service menu and set it.
Dec 23, 2007 | Samsung HCN436W 43" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
479 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
