Toshiba TP55F81 going into protection mode
I recently purchased a the TV in the subject knowing it had an issue. I thought it was the IC convergence chips but found out tonight it wasn't. The problem seems to be within the red circuitry/gun. As the set works fine if the circuit card on the red yoke is pulled off. Leave it on and all you get is a red screen with vertical white concave lines for approximately 10 seconds and then the set goes into protection mode.
Any Ideas???
Thanks
  • bigl31 Feb 01, 2008
    Gents this Set is was made in 1997 so its not new or under any kind of warranty. I just got it cheap on ebay by accident. .99 cents! It worked perfectly fine when I got it home for two or three power on cycles then the problem appeared. The guy I got it from said it had a problem but didnt have it looked at and just wanted rid of it. He had bought a new set already.
  • bigl31 Feb 02, 2008
    Im begining to think this site sucks! What kind of answers are those anyway & why if you know nothing about TV's would you respond. I need someone who has the full service manual who would actually talk to me with some intelligence.
    Thanks for wasting my time & money!!!
  • 66 Answers
Sir
well if you purachased the tv recently and if any problem is there then you must use your warranty period oderwise if you will do something then it might work against you getting new tv so sir go for the warranty its the best option right now ,i will try and help you if this doesnt work!!
Posted on Feb 01, 2008
  • 43 Answers
The problem is with the circuit board, there has to be a short somewhere either in the connection to the circuit board or the board itself. The only reason the tv would go into protection is dur to an overheat on the board. My guess is if you replace the red circuit board you fix your problem.
  • 749 Answers
Sir,
Since you have recently purchased that TV... It is best to return it have it changed with a new one... It has still a warranty, right? So why give yourself a problem... It is your right as a customer to get satisfied with what was bought. Remember you pay them for that... Exercise your right!
Go!
  • Rommel Balcita Feb 02, 2008
    OKEY FORGET WARRANTY...
    I can offer is to trace the red signal and see where it gets weak. If you put a mostly white screen up you should have more or less equal voltages all the way from the input cable to the cathode pins on the CRT, you have three identical circuits which are relatively simple, so it should be fairly straightforward to trace them as the color signals often go straight to the little neck board and don't even pass through the big main board.
    Check the crt voltages, that should lead you to the problem (although it could be a tube fault).
    First, measure the cathode voltages. One should be a lot higher than the others. If they are all about the same, the CRT is weak. I've seen a lot of bad video output ICs in monitors. Bad soldering on the CRT board is also common with some monitors. The good news is that the entire video circuit is normally on the CRT board, so it's easy to get to and trace.
    The CRT socket is always a prime suspect, even if it looks good, reheat the joints (especially on a intermittent)....
    The loss (or intermittent failure before loss) of a color on a CRT
    monitor is a common and simple problem that can be fixed without any schematic.
    In fact, a schematic cannot help.
    Unplug monitor, remove case, and if you want extra safety, connect a wire to the chassis (ground) first, and then to the HV cap on the CRT.
    Unplug the circuit board from the back of the CRT and unsolder the metal shielding box around it; there are usually tabs that need to be untwisted as well, so that the box can be removed.
    Then use solder wick to remove old solder from the socket leads at the PCB; and then freshly re-solder them (no need to blob as much on as was done originally).
    Replace the shield can, but do not re-twist the tabs (no need, and they could break off) - just re-solder.
    If you used a safety wire, remove it from the CRT cap first, then
    from ground. Then put the case back on, and you will be in business from one to 4 years more.
    If you look carefully, you will note a sponge in the back of the case that (when on) presses against that metal case, thereby creating stress on the solder connections from the PCB to the CRT socket.
    It is that stress which aggravates electromigration of the solder,
    creating the equivalent of a cold solder joint and/or open.
    The reason for the sponge is to help decrease shock on the CRT during transportation.
    There you go... That's all I got, just be careful...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
43FDX01B Red Convergence Issue
yea , sorry that( 10b ) was the closest(to 01b) I could find(free), but on page 91 of the manual it shows the convergence IC's and it has an initial for each color and if it is the horizontal or vertical ( RH,RV, ect..)and on the RH line is where you are going to look for a bad resisitor or a protection fuse , but you should replace the IC's since they are being subjected to this problem and plus they may be at the end of thier life and resistors may be loosing thier values
I would definately find the cause first(resistor , protect component , STK IC) before replacing them all
let me know your progress and findings or any other assistance you need
Mar 17, 2009 | Hitachi 43FDX01B TV
Mitsubishi wt-46809
the vertical deflection IC if defective will cause the protection circut not to let the tv power up ,it has a thermal protection circut as well
here is the vertical deflection IC # la78045
and here is a link for the NTE equivalent part and specifications and pin layout
http://www.nteinc.com/specs/7200to7299/pdf/nte7209.pdf WARNING if you heat up any component to long or with to hot of an iron you can dammage the component and or the thermal protection circut
but I believe you will also have to replace the flyback (high voltage transformer ) with wire giving to much voltage
Oct 11, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
change......
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba theaterview lines don't line up
Convergence IC blown stk392-???
Dec 03, 2007 | Televison & Video
Toshiba tv convergence problem
did you change the resisters the same time as the ic? some have reported that they got generic IC (cheaper) and have failed.
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 06, 2007 | Toshiba TP71G90 71" Rear Projection...
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
