SanDisk Sansa m240 MP3 Player Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mp3 wont charge
My mp3 wont charge
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Jan 02, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175453
Points
1850
This issue may be resolved by resetting it, try this.
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
MP3 WONT TURN ON
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mp3 wont turn on...
Press the Reset button then try charging it and if it doesn't begin to charge then take it to Radio shack.
1helpful
Wont charge
Your mp3 player is shot. Your circuit board in your mp3 player has fried. You will need to go out and buy a new one.
Mike
Samsung mp3 mini wont turn on.
you should be charging your mp3 using the cable provided by the manfacturer.check for any defects in that cable (like wear or tear).try a different cable from someone else(friends) and check if its charging..if it does so then buy a new cable separately..
Y wont the razor phone charger charge my MP3
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
Wont charge
Will It Charge On Anything? If Not Then Its Most Likely Your Battery.
You Can Get A New One From Ebay. Click Here
My philips go gear mp3 wont turn on to charge
Take something really skinny like a saftey pin and press the little reset button thts next to the lock switch
3answers
Sansa Clip Mp3 Player
format it
by connecting to computer
Recharge
you probably have charged the battery when it wasn't empty and got a memory effect
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
