Question about SanDisk Sansa m240 MP3 Player
Headphone jack whatever headphones or speakers I attach to it I have to play with it and turn it, or hold it in for it to work. is there a way to clean out the jack?
    Sergeant:
    Champion:
  • 322 Answers
No but if your very carefull and look you should see a little peace of flat meatal using somthing very small and pointed carefully force the metal out or if under waranty take it back
Posted on Feb 01, 2008
I want to connect a Sony Wireless headphone to the receiver w/o disabling the speakers.
Normally you shuould connect the headphone inserting the plug in receiver's jjack. If you've gou no jack, you can't use the headphone
Jun 02, 2015 | Onkyo TX-DS474 Receiver
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Turning off the speakers
When you plug into the headphone jack, it should automatically override the speakers. This will be either a driver issue or a device faliure (headphone jack) Start by updating the sound drivers from Dell's support site. Then update your media player. If these don't work then it's the jack.
Jun 30, 2008 | Dell Latitude D600 Notebook
SanDisk Sansa m240 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
