Toshiba Satellite M105  PC Notebook
Problem for Toshiba Satellite M105 (032017538474) PC Notebook
Toshiba M105-S322 Locks Up
By Cephus on Feb 01, 2008
I've got a Toshiba M105-S322 laptop that freezes at random requiring a soft reboot. Sometimes it'll happen right after boot, sometimes it'll go for hours without a hitch. I'd say it's software related but I'm seeing where the system seems to have trouble consistently seeing the memory, sometimes it'll read 512MB, sometimes it'll see 1GB. I'm going to go ahead and replace the memory, but is there some way to find out if it's the MB before I do so? If it's a bad MB, I'll probably just replace the computer. Any suggestions would be appreciated.
Thanks.
Comments:
Feb 01, 2008
- I've already pulled both sticks of memory and made sure they were properly seated. This last time, it was reporting 512MB, I pulled one out and rebooted, it still reported 512MB (so I assumed that the one I pulled was the bad one). I replaced it and the system saw 1GB, but the system still locked within a few minutes. It seems to recognize both or not at random.
I've also tried the software route, I've gone back and reinstalled from the Toshiba system backup CD and it didn't solve the problem.
Feb 01, 2008
- Yes, I did format the drive when I reinstalled and I haven't replaced the memory yet but I'll buy 2 new identical sticks when I do. I'm going to try switching out one of the current sticks with another that I have here, just to see if it helps with the problem.
Feb 09, 2008
- I finally got around to switching out the memory and it didn't fix the problem at all. I switched the existing memory between the two slots, switched out with new memory one stick at a time, no go. It still locks up.
My next step is to strip it down to the CPU and make sure it's solidly in place. Unfortunately, there are a couple of stripped screws that I'll have to drill out before I can open up the case. I figure it's got to be a hardware problem, the system doesn't even boot up most of the time, it might get to the BIOS but not necessarily.
Feb 10, 2008
- Nope, didn't solve the problem. I stripped the laptop all the way down, pulled the CPU and made sure everything was perfectly connected. Regreased the CPU properly with Arctic Silver 5 (it looked pretty spotty when I pulled it), reassembled the whole laptop and it's still having the same problem. It booted up immediately when I tested it, I let it sit for a couple hours and now... won't boot at all. You turn the power on, it's on for about 2 seconds then shuts off again. It's not even getting to POST.
Feb 15, 2008
- Guest, your problem is definitely software related, you should be able to solve it by repairing or re-installing Windows with the original installation disk.
Same Problem
Feb 16, 2009
-   I just replaced the LCD and after using the restore cd the laptop freezes shortly after booting to the desktop.I can get into safemode with no problems but not normal boot.I've also used a New XP install CD and it does the same, and suggestings-   Jninja2
Best Solution
posted on Feb 01, 2008
Helpful)
melnavz
Rank: Wiz
Rating: 84%, 729 votes
Remove the memory, maybe you can see the capacity of the memory. I guess you have two memory in the laptop 2 -512 mb. sometimes the system recognize to memory and sometimes only one memory can be recognize.
Maybe you can fix it by your self. try to fix well the memory and start the system and see if the two memory was recognize. if not then you should replace either of the two memory or replace it with one 1GB memory capacity.
hope this help.
Comments:
Feb 01, 2008
- since that you reinstall the system, did you format the hard drive. Is you new memory same specification woth old one? the memory should be the same specs. Please clean the old memory with eraser and sure not to damage the some IC. and clean also the memory bank maybe some dust on it.
thank you may this help.
Feb 02, 2008
- Hope work fine for you.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
AvioriX
Rank: Guru  Toshiba StaffToshiba Staff
Rating: 90%, 646 votes
Hi
You need to follow some simple steps to boost up your speed. Before using the 3rd party utilities I suggest you to start with windows own utilities. Perform disk clean up,
Start> All Programs > Accessories > System Tools > Disk Clean up
Reduce the quantity of startup programs simple type MSCONFIG after open the Run option and enter. uncheck the non essential applications (You can consider non essential all softwares aside hotkey utility and antivirus software). After click on apply and OK restart prompt will appear. "Don't Restart"
Go to My Computer, Right click on C drive and choose "Properties" click the Tools tab and click on the check now button in Disk error checking area. Check both of the boxes when it prompt. And click on OK. It will inform you that system unable to check as its in use therefore it will start when you restart computer. It will perform 5 steps error checking. It might take up to 1 hour.
Once computer start it will be definitely faster. however you have still many ways to choose better performance over some value added features. Like you can choose best performance instead of best appearance at performance settings area. Also you can disable System Restore feature this will increase performance and speed while feature will be not available.
Please post your questions if further assistance needed.
Good Luck.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite M105 PC
Questions and Unsolved Problems for Toshiba Satellite M105 PC
Do you recommend Toshiba Satellite M105 (032017538474) PC Notebook?
Answer
Answer
My labtop mouse just stopped working. I rebooted my computer and it just will not work how can i fix... (More)
Answer
the speakers make a static/buzz sound when system is idle
Answer
Toshiba A210 19T notebook.running xr home recently just started goes past post then starts to beep... (More)
Answer
I have a livebox B100 conected to my desktop (working fine). I have a wi-fi laptop which has worked... (More)
Answer
i am having issues when i try to view a video movies/songs n links even from you tube it keeps on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite M105 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
