Question about Lexmark X5150 All-In-One InkJet Printer
Error code 0502 lexmark 5150
I have cleaned the rail as per the other bit of advice but still no go help???????????
  • 2 more comments
  • rayah Feb 11, 2008
    i was printing then i heard a loud noise now all it says is hardware error 0502 what should i do?
  • Anonymous Dec 01, 2008
    same printer, same hardware error, yet I had cleaned the rod, and poked and prodded, and my printer prints about an inch, then misses an inch then comes up with the same error!
  • sugar bee Dec 05, 2008
    the printing is very light and look like line are in it also says hardware erro 0502
  • djsanker77 Feb 28, 2009
    error code 0502
    Scholar:
  • 124 Answers
Send me an E-Mail at simard2@comcast.net and I will be able to send you the step by step directions to your issue.
Thank you for using Fix Ya!
Have a great one.
Posted on Feb 23, 2009
A group of people who belong to lifestyle one are promising to show me how to start up my own online business , should i trust them , if not then why not ?
Hi,I dont know about this group lifestyle,but in the past I got drawn into sites and thay all promise you the world,and take your money,this is a brand new programe quick get in before theres no more spaces,I lost alot of money over trying to make what thay call easy money.
my advice dont get involved.
all the best to you which ever way you go with it.
Mar 24, 2015 | Computers & Internet
Hello, my name is Lawrence K. I bought a Skil rail & stile router bit set.My question to anyone who may be familiar with this product is do you separate the rail & stile bit to do each...
If you are referring to the 91704 set, the bit remains together and you raise or lower it to make the various cuts.
not exactly the same, but this article I wrote for Woodworker's Journal in 2009 should help: http://www.woodworkersjournal.com/not-just-a-door-bit/
ralph
Jan 04, 2015 | Skil Ogee Stile Rail Bit Set with 1/2-in...
How do I known if the front frame rails are bent
The checking of the frame rails for accident damage can be done easily. First place the vehicle over a flat clean cement floor. Select points on the frame rails such as front ends---suspension points---brackets attached to the rails on both sides and rear ends of rail. Make sure the points selected have a corresponding point on the other rail. Using a plumb bob drop the selected point to the floor and make a cross on the floor at that point. . Repeat the process for each selected point. The more points the easier to find where the rails are bent and by how much. Move the car out of the way and using a tape measure the distance diagonally between same points.-- EI-- from left hand front end to right hand rear end. Repeat the measuring from the opposite corners By measuring from one point on one side to the second point on the other side you will develop a continually crossing pattern of measurements. So in the end if you selected 4 points per side you will have 3 sets diagonal measurements on the floor or more . As you measure write the dimension on the floor. Now if there is a difference of more than 1/4 "(6mm)between any set of diagonals you will see if the rails are bent and if they are bent right or left or bowed in the middle. By measuring the heights of the corresponding points and recording them you will see if the rails are bent up or down. I understand it is a bit long winded but you will be in effect transposing the measurements of the points of the rails onto the floor so that the differences can be measured without the problems of items interfering with straight line distances.
Sep 20, 2013 | 1993 GMC Jimmy
How should I clean my air hockey table?
The best way to clean the surface of your table is with isopropyl alcohol and paper towel. Either spray it on the table surface with a spray bottle, or cover most of the bottle's mouth with your thumb and shake a little bit of it on the table at a time, so as not to use too much at once. Dry it off immediately with the towels, so that the alcohol doesn't soak up into the table surface. There is on important thing you have to remember, do not clean the inside of the table rails! The dirt and grime on the inside of the rails actually helps keep the puck from flying off the table.
Jul 25, 2012 | Sport & Outdoor - Others
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
We have a panasonic tv, model pt-60lc13, bought new in 2003. we use it less than 1 hr per day (last year we watched 2 movies). today, I turned the tv on, the green power light would blink slowly for...
This sounds like a power supply problem, or a vertical issue. The Panasonic sets are one of the best tv's out there and generally worth fixing, but it will need a tv technician to resolve the issues.
Jan 16, 2011 | Panasonic Televison & Video
My Lexmark 5600 printer will not print without going over boarder. I have set the printer preferences on both borderless and non borderless and this still doesn't help. The letters either run off the side...
Check the head carrier whether it runs both ends or not if it does not run up to the end area then there may be some obstacles inside the rail or shaft of the printer .Try to clean the head and carrier's rail so that it can run both the ends . I think it will print as per your need.
Dec 05, 2017 | Lexmark Office Equipment & Supplies
CD ''SKIPS'' on one player while it plays fine on another. Why does it SKIP?
Simply put it's the quality of the players. This could even be that one has a bit of dust on the read head or laser and the other is clean. Try some canned air (available at most office supply stores) to blow out any dust and debris. As for the cd, most people believe a cd must be nice and shiny or it will not work. This is incorrect. Most devices used to buff out scratches on cd's will leave a dull finish. Try some plastic polishing paste. Polish in a straight line from the center to the outer edge, working your way around.
Hope this helps.
Sep 17, 2009 | Audio Players & Recorders
Life Like train hesitates and stops altogether.
It sounds like you have eliminated the motor as the problem. Try cleaning all of the electrical contacts including the connections between rail sections and the hot rail with fine steel wool (make sure you clean up all of the remaining steel wool bits since they are conductive). If that doesn't work, look at the transformer output.
Mar 05, 2009 | Life Like Collectible Train Set
On reaching track 10 to 12 on any cd playing on my Teca cd player it continually jumps tracks back and forward.
Hi derek55
Your unit will need a clean and service. The laser moves backwards and forwards on on 2 rails.These rails are notorious for the grease drying out and impeding the traverse of the mechanism. the solution is to strip the unit, remove the rails and clean them, reinsert with new graphite grease to prevent the problem reoccurring. In some cases it may be a faulty interconnect loom to the laser assembly, and in even fewer cases it may be a faulty spindle motor whose bearing tolerances have passed what the transport can cope with. Whilst in there, clean the laser lens with a cotton bud moistened with windex glass cleaner, then polish off any smears or residue left behind.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 03, 2008 | Audio Players & Recorders
Lexmark X5150 All-In-One InkJet Printer Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
