Compaq Evo N1000C Notebook Logo
Posted on Jan 02, 2010
Power-on password on/off key - Compaq Evo N1000C Notebook
tip
How to Reset Power On Password if I Forgot
Commonly, we would like to configure a laptop power on password or to enter administrator password for PC base on Windows 7, XP, Vista, 2000, etc. For example, <b><a href="http://windowspasswordrecovery.net/article/thinkpad-password-reset.html"><u>ThinkPad power on password</u></a></b> is the most popular. It is to prevent unauthorized users from accessing our computer. While, if we <b><u>forgot power on password</u></b>, it will also prevent us from entering laptop. We now need help on how to remove, recover, bypass or <b>reset power on password</b>.<br /><br /> Luckily, for most laptops, there is Metal-Oxide Semiconductor battery which can charge the power on password to memory on the computer. So, battery also can help us <b>disable password on password</b> to login PC at ease.<br /> A. Power off computer;<br /> B. Removed the battery and disconnected every cable;<br /> C. Short-circuit the two password pads (two small square holes);<br /> D. Under the short-circuit condition, power on the computer and wait until the POST (Power On Self Test) ends. After the POST ends, the password prompt does not appear. The <b>power on password reset</b> is finished.<br /><br /> If we need to reactivate the forgotten password, let's <b>set power on password</b> again.<br /> 1. Power on computer;<br /> 2. Press F2 or other keys to login BIOS screen and select Security screen;<br /> 3. Choose Set User Password or Set System Password and press Enter key with arrow keys;<br /> 4. Input password and press Enter key. Then confirm password as the wizard.<br /> 5. Save all changes and logout BIOS screen by pressing F10 key;<br /> 6. Restart system after YES confirmed.<br /><br /> If we are not practiced PC users, it may be hard for us to bypass power on password with the above methods. The most usual case is that computer users has set Windows password, and will directly refer to Windows Password Recovery tool to unlock password quickly and easily!<br /> 3 easy ways to deal with Windows password reset problem:<br /> A. Download <b><a href="http://windowspasswordrecovery.net/"><u>Windows Password Recovery Corporation</u></a></b> and burn its .iso file into a blank USB Flash Drive or CD/DVD on an accessible computer; <br /> B. Boot the burned CD/DVD or USB Flash Drive from the PC forgotten password; <br /> C. Reset a new Windows password.<br /><br /> Whatever for laptop Windows 7, XP, Vista, 2000, Windows Server 2000, 2003, 2008, etc. administrator password, the above <i>Windows Password Recovery Corporation</i> can suit for these Microsoft Windows OS.<br /><br /> Hope the above on <b><u>power on password reset</u></b> or removal help more PC users! Sincerely welcome to share more info on power on password with all of us!<br /><br /> Article Source: http://windowspasswordrecovery.net/article/reset-power-on-password.html<br />
on Jun 13, 2011 • Computers & Internet
tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 • Computers & Internet
Power-on Password
b> If your HP Compaq 6715B laptop is lost or stolen, the power-on password can protect the valuable data on your computer. Even so, there may be times you'll want to clear that password and knowing the right procedure will make that easier. Once the power-on password is cleared, the Compaq 6715B will no longer require you to enter a password just to start up your laptop.
Shut down your Compaq 6715B and wait for it to power off. Press the "Power" button to restart the laptop. Tap the "F10" key after the Compaq splash screen appears. Wait for the setup menu to appear. Use the arrow keys to navigate to the "Security" menu and scroll down to the "Power On Password" option. Delete the entries in both boxes, then press the "F10" key. Choose the "Save Changes and Exit" option to exit the setup menu. Wait for the laptop to restart and verify that the laptop does not prompt for a power-on password. Hope this helps.
Please tell me master password key for power-on password of hp compaq nc6220.i have already tried to remove bios battery but i can not remove my power-on password
You would have to perform this in the BIOS ( Basic Input/Output System) Here are the steps:
1. Restart your computer. 2. Enter the BIOS by pressing the designated key (usually F1, F2, or Delete key).You will be able to enter the BIOS by pressing any of those keys..(this is the black screen that appears before your window starts up) 3. Inside BIOS, navigate the "menu" option by using the "arrow keys" 4. Search for "user password,system password, or power-on password" as it may vary depending to your system. It should show you "enabled or Active" and you have an option to "disable it" 5. Make the "disable password" press enter. 6. Click the "Save Changes" or "Save Changes and Exit" option in the system and it should not ask you for a password the next time you turn your computer on.
---for your reference, the command help is shown at the bottom of the BIOS screen which will guide you which keys to use while navigating inside it.
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
4helpful
3answers
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
3answers
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Power-on password for a compaq evo
please follow bello mention steps;-
1. restart the system
2. press delete key till BIOS set up not comming
3. click on power mangment option
4. chouse "user Password" option
5. as you click on the user password opetion it will be display a box for password, press enter key and not set up a password. after that when you will restart your system, after that it will be bypass the power up password.
regards
harry
2answers
Password
cannot reset to the default password
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
