Question about RIM BlackBerry Pearl 8100
White screen on display
When i slide up the phone, sometimes nothing appears on display other than white display but it happen only sometimes and no command can be done it just hang
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
It seems the os of your pda got corrupted..just format your phone and reinstall the os...and this will solve your problem
all the best
Posted on Feb 01, 2008
My display settings are messing up. Sometimes when I turn on my phone the display screen will but upside down or all white. I can sometimes fix this problem by taking the battery out and in, or by...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Sep 25, 2010 | Motorola Mobility RAZR V3
Display problem
tray to change ribbon wire (Flexible cable) its often happen on phone with slide model.
May 19, 2010 | Sony Ericsson F305 White +512MB Unlocked...
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
How do you fix the white screen on a motorola razr? I have tried to reset the battery and reboot the device, however, all i get is a white screen screen. The phone works find, just now display (very weak...
Good luck.
May 11, 2010 | Motorola Mobility RAZR V3
When I try to slide my phone open to type the display skews at an angle and becomes unreadable. If I close it back, part of the screen will go white. sometimes the top and bottom go white, but you can...
Maybe a magnet has come loose in the handset, Or you have exposed it to a magnet. Or there is a loose conection when you slide the handset. Either way you will need a new display
Oct 10, 2009 | Motorola Mobility Rival A455 Cell Phone
SGH- J600 - White Screen when I Slide up and Down.
your phn patta has been damage..chng it from service center
Sep 24, 2009 | Samsung SGH-J600 Cellular Phone
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
RIM BlackBerry  Pearl  8100 Logo
61 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
