Question about ASUS A8N-SLI Deluxe Motherboard
Memory problem. I have an Asus a8n sli deluxe mother board. I bought crucial ballistix tracer memory and I get memory problem notifications from microsoft even though the memory works well. I returned it for new memory and got the same problem. I currently have standard crucial memory which works well without any error message.
    President:
  • 2,351 Answers
Check your manual pg. 2-12. Qualified Vendors List. The QVL is tested memory for your board. There was a small fix to memory with bios version 1015. Go to Asus web site for information regarding this update & others. http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Feb 01, 2008
  • Mike Peluso
    Mike Peluso Feb 01, 2008
    I'd like to know what Operating System you are using & the total amount of memory installed. 1 dimm or 2 dimms?
6ya staff
SOURCE:
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Asus a8n-sli deluxe long beeps
Are you absolutely certain that your chip is compatible with your motherboard?
Oct 01, 2008 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
