Question about Dell A940 All-In-One InkJet Printer
Scanning problem with A940 AIO Dell printer/scanner
I recently reinstalled my operating system (Windows XP) and reinstalled the printer drivers both from the Dell website and from the CD. When I click "Scan" nothing happens. It copies and prints fine, though. I went into the control panel and opened "scanners and cameras" and clicked on that and nothing happened. Any help??? Thanks!
  • 13 more comments
  • galaxz3002 Feb 04, 2008
    Frosty555: Yes, I reinstalled the cd, as well. Still nothing.
  • mikecant Feb 09, 2008
    Exactly the same problem; it started spontaneously - and I have reinstalled the CD.
  • Grace Segal Feb 15, 2008
    The same problem happened to me, exactly the same.
  • BobbyKidd Mar 13, 2008
    I just purchased my Dell 1501 Inspiron Note book and can not get my Dell A940 to scan any documents . My old Dell 8500 worked perfect, Nothing works on the Scan ? Why is this? Please advise. bobbydesoto@gmail.com
  • Anonymous Apr 06, 2008
    Printing & Copying works fine - haven't used the fax, but my real problem is getting the Scanner to work - nothing happens when I press the scan button although this worked prior to installing windows XP.
  • black sauki Oct 10, 2008
    scanner doesn't work. works for everything else but WILL NOT SCAN. i pushed all the buttons and nothing happens. hopefully someone has the solution to this problem.
  • ferrari1477 Oct 24, 2008
    brought the all-in-one home from Antonio's Pizza. put it on my girlfriends laptop and it prints, copies but no scan. i select where i want it to go, then push the scan button and it says its "scanning to file" but nothing happens....
  • gaudiojo Oct 29, 2008
    same problem
  • Anonymous Nov 07, 2008
    Dell A940. Printer works. Copier works. Scanner does not work. It recognizes when the computer it not connected, but it will not scan the items on the glass.
  • eeleanor9855 Nov 11, 2008
    i have the same problem i have used the canner before and it worked fine but now when i try to use it it wont work i select scan to file then select scan but nothing happens even though it say scanning to file.
  • JoeBott Nov 25, 2008
    scanner does not respond.  It says "scanning to file" or email, but nothing happens
  • donald e schade Dec 11, 2008
    Did any of these people find a solution to the problem of not being able to get the scan function to work after pressing the "scan" button?
    I have same problem now after I had to switch laptops from my Dell to a HP/Compaq. Scan works if I invoke it by clicking on the printer/scanner icon under My Computer, but it doesn't initiate the Fax Tools software that it use to when I had a Dell computer.
  • davidcholl Dec 11, 2008
    I have an A940 All-in-One Printer and it will do everything except scan. When I press Scan it just sits there. Nothing.
  • endopros Jan 03, 2009
    Dell A940 will not scan. States computer not connected. Any help? I've checked connection and electric connection and reinserted. No use.
    Thanks
    endopros@hotmail.com
  • Frosty555 May 11, 2010
    You installed the drivers, but did you install the actual software that came with the printer too?
    Hi there, just found this solution to work perfectly. i just freaked out for a moment with the same problem. Use this or just type fax and scan in your help function. Hope this helps!
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
  4. In the New Scan dialog box, click the Profile list, and then click Photo. The default settings for scanning a picture are automatically displayed.
  5. If you're using a scanner with a document feeder, click the Paper size list, and then click the size of the picture that you've placed on the scanner or click the size that most closely matches the picture.
  6. Click the Color format list, and then click the color format that you want the scanned file to display.
  7. Click the File type list, and then click the file type that you want to use to save the scanned file.
  8. Click the Resolution (DPI) list, and then click the resolution, in dots per inch, that you want to use.
  9. Adjust the brightness and contrast settings or type the values that you want to use.
  10. To see how the picture will appear when it is scanned, click Preview. If needed, modify the scan settings, and then preview the picture again. Repeat these steps until you're satisfied with the preview results. Some scanners might require you to place the picture in the document feeder each time that you scan.
  11. Click Scan. When the scan is complete, Windows Photo Gallery prompts you to tag the picture so that it's easier to organize or find later.
  12. In the Tag these pictures (optional) list, type a tag name, and then click Import. Windows Photo Gallery displays the picture so you can view, fix, or organize it.
Posted on Feb 06, 2009
    Problem Solver:
  • 5 Answers
Hi All,
I spent more than one hour: searched the Internet, tried changing the Drivers, checked the USB cable, restarted Printer, Computer, running Eusing Registry cleaner, checking hardware/device errors.... Eventually I went to Dell site and made the same search and within minutes it works fine!!!
SOLUTION: Just unplug the electrical connection from wall and reconnect... (6 years old solution)
You can read it here ( http://en.community.dell.com/forums/t/4367315.aspx ).
Hope everyone who comes here will be happy.
Regards,
chandra
Posted on Dec 30, 2008
  • 1 more comment
  • randay Apr 17, 2011
    in 2011 this still works... Thanks! Spent hours trying to fix it and unplugging fixed it in three seconds!!!!
  • ACS2008 Apr 17, 2011
    Good to know that still it works and people find it useful. Thanks for the comment.
  • creiglovelac
    creiglovelac Jan 06, 2012
    Me too! We haven't been able to use ours until YOU! THANKS!
SCANNER SHOWS ERROR ON SCREEN WHEN I PUSH SCAN....
Posted on Jul 21, 2010
Had pc reformatted after a virus now my dell AIO 924 scanner will not work help
Posted on Mar 24, 2010
I had the same problem. I brought a new laptop and reinstalled the printer and everything worked except my scanner. After researching everywhere and trying to troubleshoot myself. I just unplugged the electrical connection. Once I replugged..what a surprise! What a simple and easy fix.. Cheers to Chandra - the thread right above mine..
T
Posted on Nov 07, 2009
  • 58 Answers
• Select the program where you want to send the scanned image.
• Select the type of image being scanned.
• Select how you will use the scan.
• Select Fax Now.
NOTE: Click See More Scan Settings to view all settings.
Posted on Feb 14, 2008
My new computer, Dell Inspiron 570 will not communicate with my old printer, Dell A940, All-in-One. How do I fix?
Hi Barbra,
Check all connections.
Have you installed the printer drivers?
Try un-installing and installing the printer drivers again.
Was there change in the operating system?[Say you were using windows xp and now you're using windows vista]You may need to install the driver that corresponds with your operating system.You can download the drivers from this link:www.siliconguide.com/drivers/device/583/
Hope this helps.Thanks!
Oct 13, 2011 | Dell A940 All-In-One InkJet Printer
I would like to buy another dell aio printer a940. Where can I get one.
Hello. You can take a look for a Dell Aio Printer A940 on the following website:
Amazon
I hope I helped!
If you have any other questions (about shipping, price, etc) please leave a reply!
Thank you for using FixYa!
May 29, 2011 | Computers & Internet
My dell A920 All In One printer/scanner/copier doesnt load
yup. remeber when you download the driver from dell site, thers an option for you to change the operating system, you need to make sure its for vista and not for xp.uninstall and reinstall the driver.
Sep 14, 2009 | Dell 922 All-In-One InkJet Printer
My Lexmark x6170 all-in-one Printer will not scan
I have the same printer, Windows Vista, and also only use the device drivers, but do not experience the problem you are having. The only problem I have with it is that scanning using MS Office 2007 times out before the image can completely transfer. So uninstalling your existing drivers and then reinstalling may do the trick.
If you still wish to install the All-In-One Center software, Lexmark will only provide the device drivers, as you have discovered. However, there are reports that the Lexmark X6100 series AIO (All-In-One) is identical to the Dell A960 AIO. And, fortunately, Dell is kind enough to provide the similar All-In-One Center software.
Click here for the 32-bit Windows XP version. (just in case)
Click here for the 32-bit Windows Vista version.
Give it a try and please report back as to whether or not it worked for you.
Jul 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printer A940 cant hook it up ,I have a new operations system
Go to this page courtesy of Dell and they have your driver for XP for that printer:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A940&os=WW1&osl=en&catid=&impid=
Its the first one that says Dell-Driver
Feb 08, 2009 | Dell A940 All-In-One InkJet Printer
Dell AIO A940 printer and Vista.
Starting ******* and doing drugs, screw this era. I hope the whole entire thing crashes!!!!!!!!!!!!
Mar 21, 2008 | Dell A940 All-In-One InkJet Printer
Scanning
Go into Control Panel and complete the Scanner Wizard provided by Windows XP, then try scanning pictures or documents again. If you have the disk to the printer/scanner autorun the installation again. It will just overwrite the old install, not a big deal. If you do not have the disk, look online for the "free installation disk Dell A940 Printer/Scanner" and run from this free website. Let me know how it goes.
Cynthia Charczenko
Jan 05, 2008 | Dell A940 All-In-One InkJet Printer
Scanning
If you are using windows XP
Click on Start,select all programs.
Select accessories.
Select paint.
Make sure you have a document on scanner bed.
Select the option of file on the top left hand side of the paint window.
Select the option"scanners and cameras".
A new window will pop up. Select the printer.
Click on scan.
Check if you are able to get a scan.
Jan 02, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
15,969 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
