Question about Zenith B27A11Z 27" TV
H.V shuts down/
Zenith 27 inch model #sm2787BT year 95 picture and sound comes ok,but after a minut high voltage shuts down,sound remains there,start tv again some times hv comes on some times not,also while tv works changing chanel tv h.v shuts down,if some one knows this problem,thank you./
  • 106 Answers
Try to check a bad conections in hv transformer and capacitor around them
Posted on Feb 04, 2008
My tv popped last night ,then shut down with an orange glow and a smell of something hot from the rear.
That's not a good sign. There are a number of parts in any TV that can put on quite a show when they fail. In many Zenith models, picture tube failure can cause this when high voltage gets back onto the circuit board. The glow you mentioned, if it was on the screen, is one symptom of such a failure.
Having this repaired is uneconomical. Labor alone may be $60 or more (I'm sure it will be...our shop charged that for a complex repair when I left the service business almost 10 years ago) and then you need parts. The repair bill could easily approach replacement cost, especially if it is the picture tube (and then it would cost more to repair than replace).
Use this as an excuse to treat yourself to a new TV. There's almost always a sale somewhere on small flat-screen models.
Feb 03, 2010 | Zenith A27A23W 27" TV
It pops and shuts off when I first turn it on. It finally stays on with sound and grey screen which changes colors. then the picture finally comes in about 20 minutes later
NEVER operate a set after it makes a loud pop. Only high voltage discharges can make such a sound. It is DANGEROUS to operate a set under those conditions. The chassis could be electrified or it could start a fire. Contact a qualified service technician.
Jan 09, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
Zenith 27" TV
I sorry to say I think you have a component failing that is related to heat. 15 years is a long time and if the TV was used in hpot conditions over the years it may well be the proble, or it's just old.
Sep 23, 2008 | Zenith C27A24T 27" TV
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
No picture or sound after a few minutes, replaced blown C812 but problem returned
Hello to all, I have a tv zenith model C27V36, and it has a problem I connect it in the series and it does not turn on and I connect it to the network(net) and immediately burns (damages) the horizontal exit that is a trasistor C5905 and it burns (damages) both resistances of the protection,I changed the trasistor C5905 for a trasistor C3997 that is 20 amps and nonetheless it burns it,there are no signs of short circuits. Could the problem be the high horizontal ocsilacion?? But since turning it on it burns(damages) the horizontal exit I do not have way of checking it, because it is automatically damaged . can someone please tell me what to do in this case??? Or where I can find an electronic diagram or a sketch??? Or can someone who has worked on this TV before h
help me out?? It is a zenith model C27V36 of 27 "..
thank you for you help.
May 15, 2008 | Zenith C27V36 27" TV
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Picture problems
If the line goes across the screen you have a loose solder joint on the vertical output IC. I've seen this happen many times in Zeniths and a lot of other sets. If the IC is not loose then there is a loose solder joint somewhere else in the vertical circuit. These IC's are 10 - 13 pin chips that operate the vertical deflection on your set. I feel like a drop of solder in the right place will fix it! Stargazer
Apr 10, 2007 | Zenith C27A24T 27" TV
NO PICTURE...BUT SOUND
Your HV circuit is defective. Most likely horizontal output transistor is shorted and you may need to replace the flyback. You need to call an expert.
Jun 06, 2006 | Zenith R56W28 56" Rear Projection...
Zenith B27A11Z 27" TV Logo
178 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
