TV shuts off by itself
It seems there is a short of some sort or interference that causes the VCR portion of the unit to try to stop and eject and then proceeds to shut the unit off. It keeps doing it if I try to turn the unit back on. I've never even used the VCR so it's not as if something in it is worn out. The only temporary solution is to shut the power to the unit off completely and turn it back on. But that seems to only work for a while till it does it all again. Since I don't use the VCR I would love to disable the VCR completely... Is that possible? I'm assuming I'd have to take it in to a repair shop or something but any help that can be offered would be fabulous! Thanks!
  • tiffanyp Feb 01, 2008
    The brand and model is Magnavox MWC20T6 - 20 inch DVD Triple Combo
  • tiffanyp Feb 02, 2008
    Thanks, I tried that after seeing it on another problem post and at this point it seems to be working.
You may have a bad sensor or dirty mode switch. Try putting a VHS tape in the VCR and just leave it in there while you watch TV. If that works don't remove the tape. That may solve your problem.
Posted on Feb 01, 2008
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
TV/VCR combo unit trying to eject non-existent tape
The problem is that the loading is out of timing by a tooth. This would explain both the attempt to load a non-existant tape as well as the unit shutting down. This unit needs to be disassembled and the belts replaced and the loading mechanism re-timed. I have done many of these with success. While time consuming because the entire unit must be taken apart, it is not a real difficult repair for anyone that has done them in the past. Where are you located so I can make a referral?
Dan
Apr 09, 2009 | Philips Televison & Video
Goes off with vcr stop or eject
Hi there!
Most combos are reliant on the operation of the VCR. So the VCR will have to be sorted out. There may also be a power supply fault depending on the age of the unit.Good Luck,JUS004
Feb 26, 2008 | Sylvania 6727DF TV
Clicking sound from VCR area
there is a infra red LED inside the unit that fails. this LED sends infra red signals to 3 other sensors for load and stop and counter. when this LED fails the mechanism thinks you are loading a tape. have a tech replace this LED.
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
I think that this might be a power supply problem. The VCR might be loading down the supply and causing the shut down. If you are going to try to fix this yourself I would shuuest you get a schematic and multimeter, and an oscilloscope, here is why, The schematic will tell you what voltages are normal, The multimeter will allow you to measure those voltages, the oscilloscope will allow you to test for ripple voltage which might be present riding on your dc voltage level. If you do not have access to this equipment or do not know how to use this type of equipment, I would suggest that you take the unit to a shop.
Oct 03, 2007 | Sylvania 6313CE 13 in. TV/VCR Combo
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Jan 05, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
