Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My waffle maker stopped working.
The light is not coming on and it does not heat anymore. Did I burn out the element or is there a fuse I can change?
    President:
  • 4,402 Answers
Try a new cord
Posted on Feb 07, 2008
My Gold medal 5020 waffle maker suddenly stopped heating. What should I look for to repair it?
There is a thermal fuse in series with the wires that go to the heating elements. The thermostat may have stopped working too.
Nov 05, 2014 | Gold Medal Products Gold Medal 5020 Giant...
I received the Professional Belgian Waffle maker as a gift and have only used it twice. During the second use, about the third waffle, the heating element stopped working. What would cause this? I was...
I think this was caused by the premature failure of a Chinese thermal fuse; they are poorly made and while the principle is sound (opens if necessary to prevent fire), the components are really poor and most appliances that use a heating element fail without cause due to the lousy quality of those parts. Because of the high levels of heat where these are mounted, they are most often spot-welded in series with the element and cannot be soldered in repair. Try contacting the manufacturer, I'm pretty sure they know of the problem.
May 28, 2011 | VillaWare 2010 Waffle Maker
WAF-6 made clicking sound while working fine, then shut off and won't light or heat
It's fuse maybe blown that's why it wont light or its heating elements already defective it's continuity is already open. Check it out if you can, you need a tester to test fuse and heater. I hope my advice give you an idea.
Mar 21, 2011 | Cuisinart WAF6 Waffle Maker
My waffle iron no longer heats up.just a red light
Had the same problem with the WMK300 that others are reporting. Plug it in, hear the click, red light goes on but unit does not heat up. Found the thermal fuse in the white insulation on the bottom unit. Found replacement at Radio Shack (http://www.radioshack.com/product/index.jsp?productId=2102788). Works great!
Nov 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Older waffle maker is not heating up
thats a high temp fuse you can jump it out to test the rest of the waffle maker but dont leave it jumped out , its not safe that way . that fuse is hard to find try google "fuse high temp 185 c " please rate this answer , i need it to "get my wings" thanks
Jan 12, 2009 | Toastmaster Kitchen Appliances - Others
Unit gets warm but not hot enough to cause ready light to come on
one of three problems . control board goes bad, high temp fuse burns out , wires burn through at element and burns out fuse and board ........ does not matter . no parts are made . i had a few if these come in a few years ago . people wanted them fixed ....... no parts then ...no parts now ........ call waring be mad , you might get something out of it
Jan 09, 2009 | Waring WMK300 Professional Belgian Waffle...
Will not heat up
Dec 25, 2008 | Waring WMK300 Professional Belgian Waffle...
Pizzelle maker 208 won't heat up.
Most appliances that work with heat, are equipped with a thermal fuse so if the thermostat fails, the fuse opens and prevents a fire. It is basically a good idea since all of our junk now comes from China and half of it is poorly designed and unreliable.
These fuses are normally not user replaceable since they are crimped or welded into series with one side of the AC line. And, they are tough as hens' teeth to find anyhow.
A year ago, I had three coffeemakers of the same model die in as many days. I took a refund.
The Toastmaster toaster we have, bought because of the name and appearance, is the absolute worst toaster we have ever owned. It regularly leaves one side of each slice burned, the other too light. I'm afraid the name means nothing anymore.
Dec 22, 2008 | Toastmaster 208 Pizelle Maker Waffle Maker
Turns on but doesn't Cook
It sounds like this is a common poblem but I found what it is. I am a mechanical engineer and fix anything and everything. I had the same thing with my Villeware model 2010. I took it apart and traced with a meter to find the problem. I found the wires to the heating elements in the bottom half melted and shorted where they cross (bad design) just past an inline fuse ( good part of the design!). I can't find any place that carries parts and contacted Villaware direct but do not expect any luck in getting a new wire harness. The fix is either the proper harness or the correct fuse and high temp wire and correct crip connectors. Bypassing the fuse or using incorrect wire would be dangerous, would destroy the control board if another short would occur or possibly lethal from shock or fire.
Feb 23, 2008 | VillaWare 2010 Waffle Maker
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
