Question about Sharp LC-32D6U 32 in. LCD Television
No Sound We have enjoyed our Aquos TV for 2 years and have had no problems. We have just started having a problem where we have no sound. If we warm up the TV and turn it on and off a few times, the sound comes back. How can we fix this problem?
  • 3 more comments
  • Satandy Mar 08, 2008
    I think I have the same problem. I hear a pop in the speakers when I turn it on and get no sound at all. I tried turning it on and off but the sound only came back on when I did a reset (not system reset). The next morning it was off again.
  • Anonymous Mar 29, 2008
    I took it in to the Sharp certified service people and they said it was the main board that needs to be replaced, an almost $800 fix. Needless to say that sucks. We're trying to see if Sharp will pay for it even though we are past warranty (you never know). Hopefully the service guy knew what he was doing...
  • Anonymous Jun 24, 2008
    I have a great picture but no sound whatsoever. I have tried the reset button and the system reset button. In the menu under options I have the audio set on fixed as the manual states.
  • thebat119 Jun 25, 2008
    We have had ours for almost 2 years. A few days ago we found that there was no sound. I thought it was the HD digital box but quickly nixed that theory when a DVD was played and also produced no sound. After pulling and proding a few cables here and there, I was some how able to get sound. I found that this needed to be done every time we turned the TV on. Now 2-3 days later I am sick and tired of it and no amount of pulling or proding is producing any sound. This problem is starting to look like a major defect with this SHARP model.
  • michelle_nyc Apr 14, 2009
    I have the SAME exact problem. I have had the Sharp 32in Aquos for 3 years and just started experiencing the sound issue. I had the cable guy here 2x! I'll have it repaired. Thanks for this site - mystery solved!
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the
PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with
electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Feb 16, 2009
  • spblank Jan 20, 2011
    No pops, just nothing or everything. Also, TV did mysteriously turn itself on once or twice.
    Sniper:
  • 53 Answers
Pop noise gives it away easily. The problem is the heat sink underneath the audio IC has melted and is shorting the audio circuit. To fix this, you'd need to take apart your TV and clean the melted residue off of the audio IC and replace it with a new Heat Insulation Pad. It's a pretty complicated job, suggest calling a local sharp authorized service center.
Posted on Mar 14, 2008
  • 3 Answers
I had no sound on my tv - everything was playing on Mono format so all I heard was a faint buzz. Reinstalling the firmware resolved the sound issue.
Posted on Jan 12, 2009
  • 54 Answers
Sir,,,kindly check the power supply or another hint is the connection of the speaker terminals,,,for a long time using it it might lose its connection,,thanksss and hope to help you,,,!!
Posted on Feb 01, 2008
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
My 37" Sharp Aquos has sound problems. The sound will go away after a few minutes and after turning the set off for a few minutes the sound will work but then the process starts again, I have had the TV...
Your lucky you got that out of it, this is a common problem with this unit, the solder that is used on the sound card doesn't like heat and melts. You can take the sound card out and clean with alcohol for a temp fix, but this is only a temp fix. Sound card cost approx. 340 bucks my fix was a sound surround system. sucks hey!
Aug 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Distorted sound, great picture on a Sharp Aquos 42" LCD
i belive that it is the brodcasts problem there is nothing wrong with your tv
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
When I first bought my Sharp Aquos 42 inch TV...I started having sound problems...turned the volume way up to 60 maximum and could hardly hear it.
Then after the TV was on for 4 or 5 hours, there would be crackling chirping popping noise. It seems after the TV heats up for awhile...there is MAJOR sound problems.
So I was advised to buy a Sony surround system and connect it to my TV...deactivate the TV volume and use ONLY the surround sound. I did that...but the surround audio cables are connected to the back of the TV and I get the exact SAME problem with chirping and crackling sounds after the TV heats up.
SHARP IS NOT BEING HONEST WITH CUSTOMERS.
There should definitely be a RECALL on the sound board.
Replacing it does nothing....the overheating of the TV just damages the new sound board and the TV has to be repaired again and again.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Some channels do not have sound.
Try the MTS button or audio button and make sure that it is set to either mono or stereo and NOT SAP.
Nov 30, 2007 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-32D6U 32 in. LCD Television Logo
457 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
